Question about Sabrent 1 Bay USB 2.0 External Drive Case
Hard drive will not spin.
When I turn on the power, the indicator light turns green and the unit beeps but the disk doesn't spin. It then continues to beep every few seconds. Is it the case or my hard drive?
  • cracker4 Jan 19, 2009
    The unit I'm using is a Sabrent ecs-u35k IDE hard drive enclosure.
I have the same problem with the same enclosure. I found out it is the power supply problem. It worked the first time out of the box. But when the black 12V/5V power supply box heats up, if I turn it off, and on again, my hard drive won't spin up. It had buzz sounds and tried to spin. I think they use a crappy power supply that can't supply enough current during drive spin up when temperature goes up.
My solution is to unplug the whole unit from the wall when you don't use it. That give the crappy power supply time to cool down, so next time when you turn it on, it'll start from cold. This solutoin worked for my 300G Seagate drive. For my smaller WD drive, it doesn't require cold start. I guess it makes sense, as bigger drives require more current to spin up.
Posted on Jan 23, 2009
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Iomega eGo was working before and not now. All it does is beep. Read on other forums that it could be a power issue. Windows sees the drive in device manager but drive doesn't spin up. Just beeps for...
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 15, 2011 | Iomega eGo 1 TB USB 20 Hard Drive
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
Ihave a 1.5tb that I have not used in months. I plugged it in and all I get is beeping noises. The green light is on in front and the unit feels warm to the touch. Any solutions?
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active untill turned off.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 18, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No beeps, no video, fans working,
no the floppy disk is not faulty, it is normal and required that the floppy disk drive light blink to indicate that the drive is working. And about the power on the power button might be stuck inside that is why it keeps turning on immediately you connect to main power
Aug 03, 2010 | Intel D845PESV Motherboard
My playstation 3 will not load up the green light comes on but nothing happen a few minutes later it says 'cannot start correct hard disk was not found' can anyone help on how to fix or how to recover my...
Try this, but keep in mind that one of the options wipes all your data.
These should be safe to use, and 'should' keep your data.
  • Restore Default Settings
  • Restore File System
  • Rebuild Database
  • Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
    Step 3:
    1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
    4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
    5. Then you will see the Safe Mode menu.
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    1. Restore Default Settings
    2. Restore File System
    3. Rebuild Database
    4. Restore PS3 System
    Oct 04, 2009 | Sony Video Game Consoles & Games
    Drive stopped working
    I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
    Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
    LaCie Big Disk
    Fixya is unable to suggest parts sources.
    Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
    Computer Won't Boot (Anything?)
    ok sounds like a bad power supply , i would get a new one
    Jan 21, 2008 | Computers & Internet
    Sabrent 1 Bay USB 2.0 External Drive Case Logo
    614 people viewed this question
    Top Sabrent Computers & Internet Experts
    Martin Murray
    Colin Stickland
    Colin Stickland
    Steve
    Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
