Question about Sharp MX-2300N Color Copier
Document feeder pulls paper in crooked bending the upper left hand side of the original causing copies or scane to have a wave effect. How do I adjust?
This has happened once before and a technician came and adjusted screwed on the back of the lid. I have tried to adjust screws, but am not sure I am working on the right area. No adjustment has worked so far.
  • 163 Answers
SOURCE: sf-1118
plese write c interrup 0 interrupt 50 copy key 1 copy key,select c and then adjust registration by changing figures
Posted on Sep 23, 2007
  • 62 Answers
SOURCE: Feeder misalignment
What model is this?
Posted on Oct 09, 2007
  • 81 Answers
SOURCE: copy to 11x17
check your settings on tray one. make sure the you set it to 11x17 by the way what is the model of your machine? don't set the machine to auto detect paper.
Posted on Mar 19, 2008
  • 2072 Answers
SOURCE: Upper feeder tray copies work fine, main feeder does not print, makes odd noise
Found the answer.
Problem:
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position. Solution: Free the Spring, by rotating it. Ensure that the Pawl moves freely in and out, and engages with the clutch.
Posted on Apr 03, 2008
goodgold
  • 389 Answers
SOURCE: HP Officejet 7310 AllInOne. 1.Had paper jam,
There is idea.. Vernee decision. Every time, when аa paper stuck you its remoove most often aptly. However this trouble meets in printers HP((. Prizhimnoy roller of the presenting the paper has distorted, he came out of its place or axis of the roller or rubber roller, be brake platform cost(stand)s not exactly, this that platform that under roller. Nothing else be can not. Thank you that so have well described the fault. If you to manage most see the jaggy of the roller of the presenting the paper, you understand, there all very frail and such could happen, Else brake platform from below under spring - this spring stress in platform from below on the centre exactly or two springs then they cost(stand) in symmetry, you it is necessary пробывать press on brake platform and come to a conclusion, has she even striking on the centre. Thank you
Posted on Sep 16, 2009
When pages come out of the copier the image is printed crooked. The paper comes out straight, so feed is correct. Image is just crooked? Why?
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy?
Jan 25, 2016 | Ricoh Aficio 2018D All-In-One Laser...
Our copystar is creating a dark line on the right side of the paper
There are a number of things that can cause this problem, below are a few things you can try.
1. Remove the process unit out as if you were going to remove a jam. There is a green piece of plastic used to clean the main charge unit. Slide it to the left then back to the right. Make sure it is seated all the way to the right in it's home position or it can cause black lines.
2. If you have a document feeder on the copier is the line only when using the document feeder?
- Determine if it is by making a copy from the glass.
- If it is only when making a copy from the document feeder then clean the small **** glass just to the left of the large glass. This glass is used only when making a copy from the document feeder.
3. If you wipe your hand across the copy and the toner wipes off then fixing unit should be replaced.
I hope this is helpful,
Shawn
Feb 18, 2011 | Copystar CS-1500 Copier
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
At scaning time show
Hi
I take it the scanner is connecting to your pc okay? the paper need to engage in the feeder. Try just putting one piece of a4 copy paper in the scanner and seeing if that will register as beng paper in the document feeder.
Kind regards Liz
Feb 19, 2009 | HP Scanjet 7800 Pass-Through Scanner
SCX 4521F multi/f keeps reporting "Document Jam"
Hello there,
If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Feb 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Jammed paper
Ensure that:
The paper is a recommended paper for inkjet printers.
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper shifts
Does it happen both off the copy glass & thru the document feeder or only off the document feeder. If both - check the side guides inside the cassette to make sure they are tight against the paper. If it only happens when using the feeder- the feeder tray needs to be adjusted. There is usually 2 screws under the document tray that when loosened allow for side to side adjustment. Moving the tray should solve the problem if it is only happening when you use the document feeder.
Mar 30, 2007 | Canon imageRUNNER 2000 Copier
Sharp MX-2300N Color Copier Logo
29 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
