Question about AT&T CORDED TELEPHONES AT&T CL2909 - corded phone w/ call waiting caller ID
AT&T CL2909 1-not posshble to send voice,2-not possible to hear -3- not dial up help please
I have anew telephone AT&T CL2909 but after a week 1-not posshble to send voice,2-after minutes not possible to hear 3-and finally not dial up help please i sure line has not problem
  • 3 Answers
Http://cdn-media-att.vtp-media.com/media/p/document2/products/%7B5A9D7833-E5B1-4913-BB01-23BF5B1FE914%7D/CL2909_UM_11_Final.pdf http://cdn-media-att.vtp-media.com/media/p/document2/products/%7B5A9D7833-E5B1-4913-BB01-23BF5B1FE914%7D/CL2909_UM_11_Final.pdf
Posted on Aug 25, 2014
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
Apr 15, 2011 | Vtech Lands Phones
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have (3) Uniden telephones in the house. We went on holidays for (2) weeks and switched off (2) of them. We switched them all on when we returned but now only one unit fully functions. The other two will...
Sounds like you need to re-register the 2 handsets that are not working properly. Sometimes the handsets must first be de-registered then re-registered to the base unit. Send a comment with the model number of the base unit and handsets if they are not original handsets and I will give specific information for your phone. I have included a link where you can download the manual for your Uniden cordless phone by model number.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 28, 2011 | Uniden Lands Phones
LOOKING FOR A MANUAL FOR lucent 9510 WIRLESS TELPHONE
Hi, Click this link for more data : http://www.vineland.org/tech/phones.pdf Regards, vote please, Jay
Lucent Telephone User's Guide (All Models) For corrections to this document, contact Steve Dantinne at sdantinne@vineland.org or 856.794.6700 x 2350 VoiceMail Welcome to Audix! The first time you use Audix you must record your name and create a password! To Log In: 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 1. The system will ask for your extension number followed by the # sign. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 2. Enter First Time Password # sign. Record Name As you use Audix, your name will be heard by you and other Audix users. Press 1 Speak your name Press 1 when finished Press # to approve Create Password You will be required to enter a new password with a minimum of 5 digits followed by the # sign. The maximum length of a password is 15 digits. Reenter your password for confirmation followed by the # sign. To Create a Personal Greeting This is what callers will hear when they reach your mailbox. Press 3 anytime you wish to do anything concerning your greeting Press 1 to create your greeting Press 1 to indicate the greeting number you are going to record then speak your greeting Press 2 then 3 to replay the greeting Press # to approve Press 1 to activate for all calls **X or **9 to hang up. To Get Messages 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 2. Enter your extension or voicemail number then press #. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 3. Enter your Password then press # You are now Logged in. Press 2 (You will hear the day, date and time the message was left and the length of the message. If the message is from another extension you will also hear the person's name and extension number) This is the header To play the message press 0 To listen to header again Press 2 then Press 3 To listen to message again Press 2 then Press 0 To Delete message Press *D To skip to next message Press # To forward Press 1 then Press 2 (record your comment) Press # when done recording. Enter the extension numbers you are forwarding to followed by #. Press # when done addressing. Press # to send. Call Handling Features Volume Control The volume control button will adjust three items. 1. If you are not using the telephone, it will adjust how loud or how softly the telephone rings. Press the up arrow to make the telephone ring louder. Press the down arrow to make the telephone ring softer. 2. If you are using the handset or receiver, it will adjust the sound of the incoming voice. The up arrow will make the voice louder. The down arrow will soften the voice. 3. If you are using your speakerphone, the volume control will adjust the sound on the speakerphone. The up arrow will make the sound louder. The down arrow will make the sound softer. Each item is independent of the other, depending on the device being used. That it what the volume bar will adjust. Hold The hold feature puts a call on hold until you can return to it. To keep a call on hold while you answer another call or perform another task. Press HOLD. The green light next to held call will blink. To return to the held call Press the call appearance button of the held call. Redial The Redial (or last number dialed), feature automatically redials the last extension or outside number dialed. To redial the last number that you dialed. 1. Press REDIAL. The last number you dialed is automatically redialed. Note: The redialed number can be an outside number, an extension, or a trunk or feature access code. Transfer The Transfer feature allows you to transfer a call from your telephone to another extension or outside number, if allowed. To send the present call to another extension or outside number 1. While on a call, press TRNSFR. (Dial Tone). Present call is put on hold, and the green light next to the held call blinks. You are given a new call appearance. 2. Dial the number to which the call is to be transferred. 3. Remain on the line and announce the call; if the line is busy or if there is no answer, return to the held call by pressing it's call appearance button. 4. Press TRNSFR again. Call is sent to the dialed number. 5. Hang up. ...............
Jan 21, 2011 | Cell Phones
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me,...
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
Oct 17, 2009 | Vtech Two Line Digital Answering Machine...
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Extensions
Call Pickup Direct
Upon hearing ringing or voice
announcement at another
telephone:
1. Lift the handset.
2. Dial the Call Pickup Direct
code 67.
3. Dial the station number of
the telephone to be
answered.
4. Converse.
Apr 09, 2008 | NEC Electra Elite 32D-1 Corded Phone
AT&T CORDED TELEPHONES AT&T CL2909 - corded phone w/ call waiting caller ID Logo
64 people viewed this question
Top AT&T CORDED TELEPHONES Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an AT&T CORDED TELEPHONES Lands Phone Expert? Answer questions, earn points and help others
