Question about SYMA Toys industrial Syma S032 Ready to Fly Gyro
Hellicopter wings all four of my wings are broken off
    Problem Solver:
  • 21 Answers
You will need to buy replacements and also check the grip sets which the blades connect to are ok as well.
Kind regards, Julian
rccontrolfreak.co.uk
Posted on Dec 03, 2013
I cant get hellicopter to charge
Maybe the battery is dead. Check the charging system/power supply. Maybe it's malfunctioning. Maybe inputs are wrong and check to see if they are working in proper order.
Jan 01, 2015 | Cameras
I need to turn idel down
  1. Origins
    • The Gold Wing Interstate can trace its roots to 1972 when Honda conceived a grand touring motorcycle based on the five- and six-cylinder racing superbikes of the 1960s. The new bikes dubbed the Gold Wing would feature a liquid-cooled four- or six-cylinder engine. In 1975, the Gold Wing GL1000 debuted with a boxer 999 cc four-cylinder engine. A year later, Honda launched the GL1000 Limited Edition, equipped with a chrome radiator, quilt-patterned seat and gold wheels.
    GL1100 Interstate
    • Following much clamoring from Honda enthusiasts, Honda launched the dressed GL1100 Gold Wing Interstate in 1980. It was the top trim level at the time, vs the Standard. Honda more or less copied the aftermarket bolt-on accessories available in motorcycles parts shops. In fact, the fairing, which is the windscreen and fiberglass protection mounted at the front of the bike to protect the rider, was not even a Honda option until the Interstate arrived. Honda now considered the Gold Wing GL1100 a true tourer with its Interstate model. However, many owners were never truly satisfied with the design as Honda focused more on performance than bodywork styling. In 1984, Honda dropped the Standard (unfaired) model altogether, and introduced the GL1200, with a 94-horsepower four-cylinder boxer engine. The GL1200 ceased production in 1987.
    GL1500 Interstate
    • Honda began tinkering with the idea of a larger Gold Wing tourer in 1984 and tested 15 different types of bikes to come with six-cylinder engine displacing 1500 cc. The result was the GL1500 that arrived in 1988. The engine was the boxer six-cylinder engine displacing 1520 cc. However, by 1984, Honda had dropped the Standard and the Interstate was Honda's base trim model under Aspencade and later, the LTD and SE trims. The Interstate's luxury accents disappeared, as Honda did not equip the 1991 models with cruise control or an onboard air suspension compressor. The stereo system was a low-end basic model and the bike did not have a reverse gear like other Honda models. Honda ceased production of the Interstate in 1996.
    GL1500 Interstate Specs
    • The Honda Gold Wing GL1500 Interstate featured a liquid-cooled four-stroke boxer six-cylinder engine with a 2.8-inch bore and 2.5-inch stroke. It had four valves per cylinder and developed 100 horsepower and 110 foot-pounds of torque. A six-speed shaft-driven transmission matched the engine. It rode on an 18-inch front tire and a 16-inch tire in the rear. Stopping power came from dual 11.6-inch front disc brakes with two-piston calipers and a single 12.4-inch rear disc brake with two-piston calipers. The tourer's seat only stood 30.1 inches tall and the frame sat on a 66.5-inch wheelbase. Its dry weight was a hefty 772 lbs. The fuel tank held 6.1 gallons.
Jan 14, 2013 | 1980 Honda GL 1100 Innerstate Gold Wing
I have a broken wing nut on my hadlebar. I'm
Depends on what's broken the wing nut is quite easy to get out, the plastic block it screws into is a bit more difficult. You need to take to top cap off (the black plastic cover where the extension handle comes out) It's held by either a small screw or a pop rivet. If a rivet you'll have to drill it out and replace with a self tapper screw or a new pop rivet. The wing nut assembly will now side up and you can access the screw at the back that keeps the wing nut from coming right out. If all you need to do is swap the wing nut you're done! But if you need to replace the plastic block you have to open up both sides, remove the handle release buttons and find a small Allen/hex key to release the plastic blocks clamped to the wire rods that links to the hubs. Then you can pull the extension handle out and access the screw blocks.
Aug 04, 2011 | Bugaboo 'Cameleon' Stroller
The mechanism in the base that is black plastic with four wings and conect and turn the chopper is broken. how can I get it?
Danoz Direct have access to spare parts. Type the name in to your browser for your nearest agency
Please rate my help++++Thanks for using FIXYA
May 23, 2010 | As Seen On TV Magic Bullet Food Processor
2 weeks ago, one wing of my agitator was broken
It leaks from the agitator drive shaft and tube seal. this one is below your agitator wings. The leak is not from any hoses. They sell this part, but the labor is not cheap unless DIY. Good luck.
Apr 18, 2010 | Washing Machines
How do i take out the broken glass in wing mirror
it's just clipped on. order the new glass and it will be obvious where the clips are on the back. the glass and backing are one unit, this is clipped onto the mirror housing in the middle.
Jun 30, 2009 | 2003 Toyota Corolla
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Broken lcd screen, need instrictions on how to replace it.
I have the tmobile wing and I have a cracked screen. I also master rest phone so now I can only accept in coming calls unless I use the voice activation to call out.
Oct 28, 2008 | T-Mobile Wing™ Smartphone
Open Questions:
See all SYMA Toys industrial Syma S032 Ready to Fly Gyro Questions
SYMA Toys industrial Syma S032 Ready to Fly Gyro Logo
59 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
