Question about Garden
Clogged will not put out steam it does not heat up oe stem andlost maunal what amount of water and salt do i put in nonnav
  • 1073 Answers
SOURCE: no steam
in the water
Posted on Apr 30, 2008
  • 1462 Answers
SOURCE: adding salt in dishwasher
that is what is supposed to happen
Posted on Sep 18, 2008
SOURCE: no mist coming out at all
on the box there is a number for questions or comments : 1-800-VAPOR-1-2 ( 1-800-827-6712 ).
Posted on Apr 12, 2009
  • 1015 Answers
SOURCE: I bought our Vicks vaporizer and it worked great
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Posted on Dec 16, 2010
  • 15 Answers
SOURCE: to much salt in the water
The final rinse setting may have moved, which will coincide with the salt/brine draw rate...the Culligan units have a funny way of doing exactly that, which, by the way, can generate a lot of revenue for them, if your on a salt route for them to deliver it to you!....I would look up a qualified and TRUSTWORTHY!!! Culligan repair tech, or a service manual to reset this final rinse.
Posted on Dec 23, 2010
Conair Lysol hand held steamer
Does it tell you to add salt to the water?(I have a cheapo little steamer that requires salt to increase the conductivity of the water-it just creates steam by running AC voltage through the water in the tank)
May 25, 2013 | Heating & Cooling
I have hard water, plugged it in, no steam. Added salt, no steam. What to do?
I have hard water as well and I wasn't getting steam. I put in a good tablespoon of salt and the steam started immediately. Try more than a pinch (if that's all you put in originally)
Oct 16, 2012 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My rowewnta steamer is not producing steam and I have lost the manual
if u have heat and no steam its prolly plugged with salt/calcium deposits, putting white vinager in the water chamber might clear the clog
May 25, 2011 | Rowenta Commercial Garment Steamer - White
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My humidifier is not working. I have cleaned the heating element. When plugged in the green turns on but that is it. The elements are not heating up to begin the vapor process.
Add salt. No more then 1/2 to 3/4tps max depending on the mineral content in your area.
The unit has two electrodes dipped into the water. Since water its self is none conductive without heavy minerals such as iron and such. You will have to add a small amount of salt until current starts flowing between the electrodes. I suggest a small pinch of salt each try until it produces the steam effect you desire.
Dec 22, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No steam output
Dec 06, 2009 - found solution: if unit is truely clean, unplug unit then mix about a teaspoon of iodized salt (table salt) to the water. Reconnect unit wait about 1 - 2 minutes, unit will start to make a grinding sound but shortly after steam will produce.
Nov 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My shark steam mop does not steam
Try cleaning the heating elements of lime deposits or adding a small amount of salt to the water.
Oct 31, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Feb 12, 2008 | Irons
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
