Question about Maytag Dishwashers
Won't turn on
Checked outlet, works fine. No power at all. Where do I check first?
  • Maytag Master
  • 3,247 Answers
Usually a tripped fuse inside the diswasher that stops power to the controller.
Will need full model number to make any further assessment.
Posted on Jan 04, 2013
FitzOriginal
  • 842 Answers
SOURCE: power interrupted during cycle. now
As a general rule, what you are describing happens if the power is interrupted for a short time and the machine doesn't get a chance to do a reset before the power comes back. There is a good chance if you power the unit off then actually unplug it from the wall and leave it 20 minutes it should do a reset and be OK. REcognising this is a built in, I would hope there is an isolator switch somewhere nearby you can flick, but if not you will have to switch the breaker that feeds the kitchen in your breaker box.
Posted on Jul 04, 2011
  • 3247 Answers
SOURCE: My Hotpoint HDA3600R00CC suddenly won't
My not starting do you imply all the lights are out or the lights are on but nothing happens when the START is pressed.
Generally the door interlock switch could be a problem if it does not start. If lights are out then the controller is out or the power supply.
Check the parts assembly for idea of parts involved.
Good luck.
Posted on Sep 02, 2011
  • 3 Answers
SOURCE: will not turn on. we
It could be in the plug itself. Check both top & bottom plugs. This could be an easy $2 fix.
Posted on Sep 06, 2011
Daniel S
  • 4323 Answers
SOURCE: My dishwasher won't power on. Checked breaker and
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the RINSE ONLY button and hold it for 15 seconds, if it's still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 13, 2011
  • 884 Answers
SOURCE: Kenmore 66517514202 dishwasher has no power dead no lights nothing
Does the wiring come up through the door at the bottom to the control panel? Check for a broken wire
Posted on May 21, 2012
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
Dewalt Mk246 won't run. , It's Brand Nu was
This is a common problem with this compressor and still is a problem in 2014.It is under powered and trips the reset
Apr 21, 2013 | Air Tools & Compressors
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Have a Sylvania 6727DF TV and it won't turn on tried different outlet different remote checked the transistors I can't find what's wrong even the ohm's r weak on the cord
Contact any experienced service technician. Its main power regulator section has the fault. The work is a skilled one, and not a user repairable fault.
Aug 26, 2012 | Sylvania 6727DF TV
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
12v power outlet doesn't work
Answer: Its a prius and you should feel bad
Jul 04, 2012 | 2002 Toyota Prius
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
Dishwashers Logo
64 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
