Question about Honeywell Programmable Thermostat Heater
Yes,a little more inf.that ight help solve my problem a little quicker.let me start from the begining.my wife kept switching from heat to air until my themostat finally stop working.it use to be hooke
Can press in on the plumer button on the contactor and the unit will kick on,but goes right off when let go..the themostat stoped working,my family switched from heat to air condition back n forth until it stoped working.i was going to replaces the white-rogers with a honeywell,which i though would be simple,so i didn,t label the wires.but then i forgot that the heat pump had been disconnect and got the heat from air handler/furnance.which gave me no clue on how to wire this new honeywell.white-rogers was a -1f58w-72,and the new honeywell is a rth2300/rth221,can anybody give me a correct wiring pattern
  • Thomas Woodburn
    Thomas Woodburn Apr 16, 2017
    With tstat off the wall wire nut red green and yellow. That's power, indoor fan and compressor. Make sure it is cooling, not heating and the compressor is running. If it is not cooling and the compressor is running add the orange wire to the bunch and try again. Once you figure out the cooling. WRITE DOWN WHAT WIRES YOU USED TO MAKE IT COOL and message me back. Remember to turn power off to AHU when messing with the tstat wires.
    New Friend:
  • 28 Answers
Only the original new manual will give you the wiring. The bad news in manufacturers do not always use the t=same colors to d the same things. God Bless
John. Same happened to me and I guessed till it started functioning properly. Sorry
Posted on Apr 16, 2017
5 Suggested Answers
billyvangogh
  • 108 Answers
SOURCE: I'm replacing my old thermostat with a honeywell
usually you should have 4 or 5 wires....if you have AC then this wire should be Y if not was it connected at all before?...Heating requires only R&W
Posted on Oct 25, 2009
  • 215 Answers
SOURCE: New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Posted on Mar 14, 2010
heatman101
  • 43501 Answers
SOURCE: Want to replace a White-Rodgers
Here is a tip that explains the wiring and the color designations...
Thermostat Wiring and Terminal Designations
Thermostat Problems - How to Change the Thermostat for Heating or Cooling
heatman101
Posted on Dec 31, 2010
flatech
  • 111 Answers
SOURCE: How does one wire a 24 volt White-Rogers evaporative cooler controller replacement for an ancient mercury switched Honeywell controller?
Red wire, R with a jumper to RH
White , W
Green, G
Yellow, Y
Make certain you understand thermostats come setup for gas, so pay attention to what your heat/cool unit is, that's very important, also make sure to shut off the power to your system before removing the thermostat.
Posted on Jul 11, 2014
I have a 2001 Suzuki Intruder VS800. it has a loud slapping noise. It does it at the beginning of start up then goes away until it warms up. Within a matter of minutes the back cylinder is heated up.
The back cylinder usually heats quicker and runs hotter and consequently is the first to develop problems. If you think the back cylinder is abnormally hot abnormally quicker there is probably a problem that is likely to manifest as a reduction in power, smoothness, economy and possibly strange or unusual noises.
It would be well to try and trace the noise using a stethoscope, sonoscope or similar device. If the noise seems to be originating from the back cylinder it should be thoroughly checked - coolant circulation, compression, cylinder leakage, fuel-air mix, etc.
Aug 10, 2016 | Suzuki Motorcycles
Need to get my wifes car heater blower working again.
CHECK THE BLOWER MOTOR RESISTOR ON THE EVAP BOX. MOST LIKELY IT IS BAD. AFTER YOU REPLACE IT THROW AWAY THE 2 SPEED SWITCH AND RESTORE WIRING BACK THE WAY IT SHOULD BE.
Dec 15, 2014 | 1997 Lincoln Continental
Overheating
There may be air trapped in the cooling system. If no air bleed on the thermostat housing, or right beside it, start engine at cold, remove radiator cap, and let it idle until warmed up and the thermostat opens fully. When at operating temperature, shut off the car, check coolant level, and put the cap back on. See if that removes any trapped air.
Jun 21, 2013 | 1992 Chevrolet Lumina
The heater in my Passat doesn't blow very hot air -- just warm.
This happened to my Passat, and little by little the air kept getting colder and colder until there was no heat left....I just took it in to get looked at- The heating core is gone- the part itself not that expensive, but since they need to take apart the entire dash to replace, the total job is like $800, $700 of that is labor!
Feb 01, 2010 | 2001 Volkswagen Passat
Lg window-type ac
Most little window units are mainly for 300-500 Square foot rooms.
Should be putting around 80-105 degrees top out of those little units, Make sure that your thermostat is set for heat rather then the normal setting of cooling (Turn more towards Heat) also if you have a fan setting you may want to try lowering the fan to low speed vs high fan, which should give you more heat.
Make sure the Filter is clean as well as the coils behind the filter or it will shut down the heaters quicker due to lack of air, shutting down your T-stat and bi-metals quicker.
Nov 11, 2009 | Heating & Cooling
Projector keeps shutting off and red light comes on
We had a projector at our church that was hooked up to a light switch to turn it on or off and it kept burning the bulbs out. We had an expert come in and look over our situation and he said When you are finished with the projector let the fan keep blowing until the unit cools down. Ours had a switch for the bulb as well as one for the fan. We turned out the bulb and left the fan on for an extra ten to fifteen minutes. That let the bulb cool down gradually If you just cut the power the bulb over heats and will burn out. Yes turning on for a few minutes will burn it our quicker as well. Hope this helps.
Mar 14, 2017 | Dell Projector Lamp for 2400MP
On off cycling, little air flow, little heat
We had the same problem with the same furnace, CODE 32 DISPLAYED ON THE LEDS. I fixed it by cutting the air inlet pipe and using a hair dryer to supply heated combustion air to the furnace. Once I did that it started to run more and more until it finally heated the house up and works fine, so far so good.
We had a severe drop in temps, sunday it was 40 and rain and that night it dropped to -5 I suspect those conditions contributed to the problem. Wife observed this has never occurred before in 14 years of operation.
Nov 13, 2008 | Kitchen Appliances - Others
2004 Gmc Envoy XUV A/C problems
Hi, do you turn the AC as soon as you start the car? If this is the case yes if will blow hot until the AC kicks in. What the ac does is not put cold air in to the vehicle it removes the heat from the air, so it does take time for it to do this.A little trick for a bit quicker is to roll down a window these just helps. I read that once it starts getting cold it stays cold is this right? Once it stays cold have you notice that if you stop for just like running into the store and you start the car back up is it still cold or does the problem starts over? Hope this helps some please let me know.
Cheers
Aug 23, 2008 | 2004 GMC Envoy
Chech engin light secondary air pump
The SAI (secondary air pump) comes on for 30-45 seconds when you first start the engine if the coolant is under 85 deg F. It pumps air through the head into the exhaust. It's purpose is to supply extra oxygen to the cats to heat them up quicker and reduce emissions. It should have no real effect on engine performance, but does help bring engine temps up quicker making the engine more efficient.
Jun 27, 2008 | 2000 Audi A6
Possible heat related problem to television.
If you had the back off ,while in there jump any switchs that are related to cover being off,turn on set kisten for fan bearings .check air path ,especially in light unit.wayne
Oct 19, 2006 | RCA D44LPW134 44" HDTV
Heating & Cooling Logo
53 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
