Question about Hi-Pro Hipro 200W ATX Power Supply p/n HP-A2027F3 200-Watt Power Supply
My SMPS burnt before 1 month.I want a new one.HP COMPAQ cabinet does not fit with ordinary SMPS.So plz help me
    Problem Solver:
  • 13 Answers
Please contact your nearest HP Service Centre or call HP helpline for a replacement as it would be under warranty.
Posted on Jan 19, 2009
How to replace power on button on a compaq CQ5320Y pc?
Option#1 Cost effective repair option:--replace the power button in ATX computer Cabinet. You can find the power button at best buy/ wallmart/ebay etc for less than $20 and that should fix the issue.
Costlier option: Buy new ATX cabinet and then get the motherboard/Hard drive/ smps/ DVD writer etc moved and rewired to new Cabinet and that should fix the issue
Sep 04, 2014 | Compaq Computers & Internet
Power failure due to something blast from the back panel or smps board,my model no is hts3541
exactly same problem has happened with me, within 1 year, now under service centre from last 1 month, they told me that this is the "SMPS" board problem and it's not available now, bcoz of the model had been discontinued, all the reader please be aware from the "philips", bcoz they used the most cheapest and ordinary material in their product and also the service are very bad
Oct 03, 2013 | Philips Audio Players & Recorders
Fan goes into high gear, won't boot up
Solution 1:
1.Disconnect all cables and connectors with in a cabinet except power supply (SMPS)take out RAM and clean it with cloth and Reinstall it on same place.And you can also check with new RAM. If this step not solve your problem,go to next step. 2.Check with New SMPS if it doesnt solve problem, your motherboard may faulty.
I think it helps..let me know
Dec 29, 2010 | HP Pavilion A820n (PP165AA) PC Desktop
No input signal
1.remove the monitor cable from cpu and connect again...
2.connect the cpu power cable properly
3.cheak the smps fan is running in rear side of cabinet.[it must be run when the cpu is on]
4.if smps fan is not running then replace the smps
then ur problem will be solved....
thank you...
all the best...
Mar 31, 2010 | HP Pavilion m7580n PC Desktop
I want new SMPS so what of Compaq Evo D510 so what can I do? because this pc having diffetent
no problem, either you can call Compaq customer care and you can place order for any part, or you can buy the mini smps manufactured by iBall, and zebronics.
Feb 10, 2010 | HP Compaq EVO D510 Intel Desktop PC -...
Don't start up..
If your computer is not switching ON you can try the following in order
1.you have to plug the power cable properly then try changing the power cable.
2. Check C P U power Button is working this can be done by opening the cabinet and switching the computer on by touching the two power button front panel pins on the motherboard with a screw driver if the computer gets started then it is the promblem with the power button in the cpu
3.Try replacing the SMPS with a new one
4. Finally change the CMOS Battery
Thanks
Jan 23, 2010 | HP Compaq Presario SR1115CL PC Desktop
Had a power outage and the computer won't come back on. Compaq Presario Desktop - SR1230NX
open CPU cabinet and give power to computer thencheck your smps is working?
it is square box where you connect power code to cpu.
If its running then it is ok.Then check for loose connection from smps to motherbord.
But if its not working then you have to change smps or repair it.
Thanks for using fixya.
Please rate solution if it helps.
Jul 25, 2009 | Computers & Internet
CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
Jun 19, 2008 | Intel D845GVSR Motherboard
Open Questions:
Hi-Pro Hipro 200W ATX Power Supply p/n HP-A2027F3 200-Watt Power Supply Logo
204 people viewed this question
Top Hi-Pro Computers & Internet Experts
Brian Sullivan
Brian Sullivan
sonic boom...
sonic boom...
danielle yancer
danielle yancer
Are you a Hi-Pro Computer and Internet Expert? Answer questions, earn points and help others
