Question about Hunter 20347 Ceiling Fan
Y59 R130C B03 27036
No AC passing through this
  • packrat65
    packrat65 Jan 07, 2013
    Removed this part and working fine
What is Part Number Y59 R 130C BO3 42207. It is from my ceiling light fixture. What is it's purpose and is it needed
Part numbers are specific to manufacturer and model. Contact them to determine what this part is and does.
Oct 13, 2016 | Dryers
Can you by pass the ac on a f 150 2001
If there is not a problem with the ac pulley bearing then to immobilise the ac compressor just disconnect the power wire to the ac clutch. The pulley then just becomes an idler pulley and the system is by passed
Jul 31, 2014 | Ford F-150 Cars & Trucks
Is it possible to by pass a AC commpressor on a 1996 vw jetta using a shorter belt ? Or just going to the parts store and asking for a belt with no ac ?
Yes you can bypass the ac compressor with a shorter belt, however it may take a few tries to get the right length belt. Even if they have a belt for a non ac Jetta, the belt sometimes isn't the right length.
Aug 10, 2012 | Cars & Trucks
Can i put on a shorter serpentine belt to by pass the ac on a 1995 buick lesabre my ac is locked up also if i can bypass the ac what size belt should i use
When you go to the Auto parts store and get the part. Tell them you don't have AC and install that belt by passing the AC pulley.
Sep 30, 2010 | 1995 Buick LeSabre
CAN THE SERPENTINE BELT BE REROUTED TO BYPASS THE A/C COMPRESSOR?
No. The bearing on the compressor can be replaced without buying an entire compressor.
Jul 27, 2010 | 2000 Oldsmobile Silhouette
Hunter 20347 Ceiling Fan Logo
265 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
