Question about Asrock K8Upgrade-1689 Motherboard
No 'line-in' socket on the Asrock k8upgrade-1689 m/b.
I want to feed in audio from record deck/tape player for which I would normally use the 'line-in' socket present on most sound cards. Please could you tell me if there is a way round this problem eg via microphone socket, which will avoid me having to purchase and fit a PCI sound card.
Thank you, Les Vayro
  • les_vayro Jan 19, 2009
    Thanks walterkai. In fact this m/b has a line in socket. I hadn't looked hard enough. Les
    Problem Solver:
  • 7 Answers
Yeah the solution is to use the microphone socket and use the neromix software.
Posted on Jan 19, 2009
Hook a tape deck to a Audiosource 100watt amp
CD player to any audio in. Tape deck requires a dedicated tape in tape out connection found in older amps/receivers.
Dec 16, 2017 | AudioSource Audio Players & Recorders
Vinyl recording turntable
The Denon will act just like a standard tape recorder. It should have an audio in, for recording. If that socket is connected to the audio out of a tape socket on your receiver, the Denon will pick up the signals that are sent to your receiver from whatever source. All you have to do is follow the instructions for recording on the Denon then. If you have lost the user manual for it, it's free on-line.
Jun 22, 2017 | Denon CDR-W1500 2-Disc CD Recorder
Do I need an amp for my 3head sony real to real tape recorder
You do need an amp of some kind. On the back of the deck will be RCA sockets, in the red and white ones you plug a line cable to the audio in sockets of an amp or receiver. The other two sockets are record. They go to the audio out of the amp.
Jan 17, 2014 | Beltronics TEAC W-600R Home Double...
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
Download mercury fsb800 mother board
Not sure what download you require, but here is a link where you can download the manual and drivers:
Hope this helps. If so, please rate. Thanks.
Apr 14, 2010 | Asrock K8Upgrade-VM800 Motherboard
Printer not recognized on K8Upgrade-1689. When
Make sure you have the latest USB driver from the manufacturer, ASRock. It's the first selection when you Google your Motherboard model code.
Does the printer come with a CD? If so, unplug the printer USB cable, reboot, and run the CD. It will hopefully ask you to plugt in the USB cable after the proper HP driver has been installed.
Aug 06, 2009 | Asrock K8Upgrade-1689 Motherboard
Drivers de placa k8upgrade vm800 de audio wdm via ac 97
Try this
Jan 22, 2009 | Asrock K8Upgrade-VM800 Motherboard
Recording from audio tape to laptop
Hi Vincent.
Just use the play out connections on the back ot the deck, and connect them straight to the line in socket on the lappy. Use a RCA stereo to 3.5mm stereo jack connection, levels will be fine. Try audacity as a decent freeware recording program. Woks well, and you can use half decent plugins to tweak the audio. :)
Jul 05, 2008 | Audio Players & Recorders
Asrock K8Upgrade-1689 Motherboard Logo
35 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
