Question about John Deere 6200 6300 6400 6500 7500 Water Pump (John Deere)
My john deere 6300 keeps blowing the 30 amp starter fuse
Everytime you turn key to start tractor the 30 amp starter fuse blows
5 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
  • 6468 Answers
SOURCE: John Deere L120 blows fuse when starting. Starter spins very briefly, then 25 amp fuse blows
one of the safety switches could be shorted out internally
Posted on Apr 10, 2012
  • 417 Answers
SOURCE: My john deere 316 tractor will start but the starter keeps spinning, even if I turn off and remove key. I must disconnect battery at times to stop the starter. Any ideas?
It's not your switch, it's your starter solenoid sticking open. Te same way the starter spins a gear up to the flywheel an retracts it when it's not receiving power, the solenoid has an electrically operated contact toggle switch inside that over years of use and very likely corrosion, has now stuck in the open or on position. Replace it, they're really cheap and extremely universal. It's a simple design so they're used in automotive applications very commonly.
Posted on Mar 02, 2015
  • 50567 Answers
SOURCE: John Deere Tractor...If you put a battery with more cranking amps than what's called for will it blow fuses? When we start the mower it continues to blow fuses. This was after the battery change.
NO
a battery with a higher crank specification only means that you can spin the engine for longer before the battery goes flat
blowing fuses is from a dead short in the wiring, battery connect up wrong, problem relays
basically the positive of the battery is through the fuse) connected directly to ground at some point
Posted on Jun 18, 2016
Lx173 John Deere wont start. starter motor will not run to start eng you hear only solenoid engaging starter drive. have tested motor on bench. started blowing fuse since solenoid replaced.
You may have a bad key switch or you have a short in the wiring somewhere. Also check the Magneto's for proper gap. If they are loose they will stick to the flywheel and prevent motor from turning and could blow fuse.
Oct 21, 2016 | John Deere Garden
NO
Jun 18, 2016 | John Deere Garden
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Mar 06, 2015 | John Deere Garden
Why does my john deere 5075e keep blowing ignition fuse
It has to have a short either at the starter or the ign. switch just check the wires that carry power and make sure none are earthing out.
Aug 17, 2014 | Garden
My john deere 790 excavator blows 30 amp fuse when i turn key on
you have a dead short in a power line after the key switch > check wires for rubbed through or wires touching earth some where.
Jun 11, 2013 | Garden
John deere z425 mower blows fuse for charing system
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 30, 2012 | John Deere Garden
John deere 250 skid loader - purchased new in late 2001. every time i turn the switch to start the engine, it blows the fuse.
Apparently you have a short in the starting circuit. I would try disconnecting the start wire from the solenoid, and see if it still blows fuse. If it does it's in the control circuit. If not it's the starter solenoid.
There should be an operator present switch under the seat, that sometimes short out from an accumulation of dirt and debris that get moist.There is also a neutral safety switch and/or relays.
Oct 17, 2010 | John Deere 4020 Gas & Diesel Tractor...
John Deere 6200 6300 6400 6500 7500 Water Pump (John Deere) Logo
156 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
