Question about Sakar Cyber Gear Slide Click Text Messenger
To restart motster high password text massesger
Reset my desktop backc to the original settings
Remove any DVDs or CDs from the optical drives and then unplug all peripheral devices except for the keyboard and mouse.
Click the "Windows" button and then type "eMachines recovery management" into the search box. Click on "eMachines recovery management" in the results list and then click the "Restore" tab.
Click "Password Settings" and then type a new password into the text box.
Click "OK" and then click "Restore System to Factory Default".
Type the recovery password into the "Password" text box and then click "OK". Click "Next" To start the recovery process.
Click "Finish" and then wait for your computer to restart.
This procedure could take several minutes. Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings.
or if you are running XP
If you set your machine back to eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order.
You should get rid of this virus with an effective virus remover.
You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html
If you know when you got the virus, you can do a system restore to a time before the virus was on your system. This article tells you how to run it from safe mode http://bertk.mvps.org/html/safemode.html
Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009.
More information here http://www.ask-the-computer-doc.com/comp...
If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one.
You might also try a Windows repair install if you have the operating system disk. Follow the directions here for XP http://www.michaelstevenstech.com/XPrepa...
Source(s):
hope this helps
Aug 01, 2012 | E-Machines eMachines Desktop PC
Lost the security key code for netgear dg834pn
Hello and welcome to FixYa!
Lets reset your router to get you a new security code!
On a computer connected to the Netgear now.
Click the link below
routerlogin.net
On the page that comes up, it will ask for a username and password.
type in password for the password, and type in admin for user name
You are inside the router..
Click on wireless, then right under it click on wireless security.
Where it says, PSK / Passphrase / Or Network key .. There is a text box to the right
In that text box is your password.. If it looks like ************
You will have to type in a new password, and click apply / save settings.
Then.. The router will restart..
You have now found out, or reset your wireless password.
**Note** If you changed the password.. The current computer will also have to reconnect to the network, and enter the new password.
If you have any other questions, let me know.
KittyTech
Sep 11, 2011 | Computers & Internet
How do I make my text size larger?
This is for windows vista:
  1. Open Personalization by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
  2. In the left pane, click Adjust font size (DPI). 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. In the DPI Scaling dialog box, do one of the following:
    • To increase the size of text and other items on the screen, click Larger scale (120 DPI)-make text more readable, and then click OK.
    • To decrease the size of text and other items on the screen, click Default scale (96 DPI)-fit more information, and then click OK.
    To see the changes, close all of your programs, and then restart Windows.
Source
Jul 19, 2011 | Dell Inspiron 2200 Notebook
Can't unlock My Essentials 1TB Hard Drive Asking for password and I don't have it.
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 26, 2011 | Western Digital My Book Essential Edition...
I forgot my password to unlocking my WD external hard drive 2 TB? How can I unlock it without loosing all my data saved?
Jan 26, 2011 | Western Digital Elements 2 TB USB 2.0...
I forget my password in u3 what can i do??????
Jan 25, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I forget the hdd password
Jan 15, 2011 | Computers & Internet
How do I change the password on the Actiontec wireless router? (Not the WPA key, but the web interface password. I just want to change it from the default "password1")
  1. Open a Web browser. In the “Address” text box, type http://192.168.0., then press Enter on the keyboard.
  2. The Web Configurator’s “Main Menu” screen appears. Select Setup/Configuration.
  3. From the Setup/Configuration screen, select Admin Username/Password from the menu on the left side.
  4. The “Change Admin Username/Password” screen appears. Enter a new user name (optional) in the “New Username” text box, then a password in the “New Password” text box. Re-enter the password in the “Re-enter New Password” text box. Make sure to write the user name and password down and keep them in a secure location.
  5. Click Save and Restart at the bottom of the screen.
  6. The “Save and Restart” page appears. Click the Save and Restart button to save the settings changed in the Change Admin Username/Password screen.
  7. Once the Gateway has rebooted, the password is active.
You can also download a user manual from here, or - if you have any more questions - just come back here and leave a comment - I'm happy to help.
Jul 04, 2010 | Actiontec GT704WG Wireless Router...
My computer is an Acer Aspire 4920G laptop.When VISTA Load comes to password prompt.But in the password prompt box have some automatically typed text.so i always delete that dots and type my exact...
click on start >> go to control panel >> double click on user accounts >> click on change password and than create a new password. restart your computer and check it then.
Jun 19, 2010 | Acer Aspire 4730-4947 Notebook
How To recover admin password f or Inspiron e1705
Restart your computer, and keep pressing F8 until you see a menu (white text on black background). Choose "start in Safe Mode".
Logon, and access Control Panel, and Users, and change passwords.
Dec 05, 2009 | Dell Inspiron E1705 Notebook
Sakar Cyber Gear Slide Click Text Messenger Logo
Top Sakar Toys Experts
Mister Danger
Are you a Sakar Toy Expert? Answer questions, earn points and help others
