Question about Dynex "- 46"" Class - LCD - 1080p - 60Hz - HDTV DX-46L150A11"
I have a 46" Dynex LCD TV that comes on, then after about 5 min - 3 hours it will turn blue or white and blue and make a really loud on going screech (That scares the hell out of me).
I have a 46" Dynex LCD TV that comes on, then after about 5 min - 3 hours it will turn blue or white and blue and make a really loud on going screech no matter the volume. The remote will not work and I have to unplug it. I can then plug it back in and the same things goes on. While moving the connectors around slightly I notice some popping sounds while the TV is on, even if it's not an audio cable I'm touching. Anyone have this issue. It's less than 3 years old.
SOURCE: Dynex remote sticks on channels and does not always lower volume
I think you'll find that the tv is at fault. I, unfortunately bought one of these **** things as well. If you try to turn the channel, or volume, at the tv itself, you'll find that it won't work either. Seems to happen when switching between HD and regular programming a lot, but can happen at any time. You get what you ( and I ) paid for....
Posted on Oct 01, 2009
Testimonial: "I believe this person is right. I thought it was the remote control but it is the Dynex tv itself"
SOURCE: New 40 in Dynex having issue
Just got off the phone with Dynex, sounds like a common problem with a recent batch.
Tech support suggested returning the tv to futureshop/bestbuy since I'm within 30 days of purchasing.
Posted on Dec 30, 2009
  • 608 Answers
SOURCE: blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
  • 55 Answers
SOURCE: Remote doesn"t work. Only have
check that all of your cables are plugged in correctly and that the input is set to to correct cables on the remote there is a button that should say input press that a menu will appear and then you can scroll through your input options keep trying until one works
there is also usually a button on the tv that does the same thing
Posted on Mar 06, 2011
SOURCE: dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Posted on Dec 28, 2011
Testimonial: "Thanks il look into them.... not sure how much they would cost to have repaired. It may b cheaper to just buy a new one but different co"
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 22 tv has sound no picture
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
Playstation 3 won't hook up to my dynex tv with
Did you check the side of the television for the AV/Compsite ports (Yellow, Red, White)? A lot of models have these connections on the side of the TV. You did not list your model number so I cannot really check for you.
May 25, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
My samsung tv has no picture or sound the blue light at the bottom is flashing and there is a loud clicking noise coming from the tv
take plug out leave it for ten min retry ..if it dont work you req to change x4 pcb boards its not chep £200... i had to do it with mine if your in bristol i can do it if need to .. 07779933829
Feb 23, 2011 | Samsung LN46A650 46 in. LCD HDTV
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
My screen is all white when i turn the tv on. the sound is ok but not the screen. i unplugged it for like 10 mins, plugged it back in and its still white. whats going on the tv isnt even a yr old yet and...
That is the symptom of the LCD panel not getting the signal from the LCD controller board due to no power to the LCD controller or blown surfaced mounted fuse on the controller board, that is the first palce to look, it can also be that the connector came off the LCD controller board.
Dec 01, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Image lost after 5 min turning on the tv, sound was ok.
I would suspect overheating of an electric component in the power supply of the lamp (backlight) of your lcd tv. bring it in for repairs.
Nov 29, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Samsung series 5 530 46" LCD
RE: Product Defect
If Its new enough to return without store rejection or if you still have a valid warranty --take it back! --
Aug 17, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Dynex "- 46"" Class - LCD - 1080p - 60Hz - HDTV DX-46L150A11" Logo
27 people viewed this question
Top Dynex Audio Players & Recorders Experts
Electric Dime
Electric Dime
Michel Laprise Sr
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
