Question about Riccar R1570 Mechanical Sewing Machine
How do I re-align my Riccar sewing machine after replacing hook drive gear?
I recently replaced what the parts list describes as the Hook Drive Gear on my Riccar 600FA sewing machine, but I'm not able to figure out how to get it "re-aligned" so that the needle doesn't hit the shuttle race cover, shuttle race holder and/or the shuttle hook (whichever it may be hitting; appears to me to be the shuttle hook). The hook drive gear that I replaced was split completely with approximately a 1/16" gap and it seems that - like a motor driven machine - the "timing" is off but I cannot figure out where the adjustments need to be made in order to "re-align" it. Can you help?
4 Suggested Answers
  • 5370 Answers
SOURCE: Setting the hook and needle timing for Riccar
When the needle has risen 2 mm from bottom dead center the point of the hook must be central to the needle and just above the eye.
----------- The hook should be at the top of its stroke inside the shuttle race. Loosen the set screw for the needle bar on the upper part of the machine, this is located on the needle bar bushing (the collar that the needle bar slides through when making a stitch). The needle bar should slide easily up and down. --------- Also for instructions with pictures and diagrams.You can obtain the manual.To get manual click this link directly:--- ------
Keep updated.This should help.Thanks.Helpmech.
Posted on Feb 27, 2011
  • 411 Answers
SOURCE: I replaced the rorary hook
check on line for timing some have timing marks on the gears
Posted on Jan 18, 2011
  • 1456 Answers
SOURCE: I have a Riccar 555su
Get a manual for the 555, it should be able to give you enough knowledge for your machine.
If not look on the website www. for a similar model.
Find out what shank your machine is and you should be able to buy parts for it. I find ebay great for sewing machine parts.
Posted on Feb 10, 2011
I found a broken plastic gear in the bottom of my touch and sew, dont know what it goes to. But I cannot wind bobbin
What you are describing is the pinion gear. It connects to the hook drive gear. these gears should be replaced as a pair. The machine will then require re-timing. I might suggest that you get a new machine as this is more expensive to fix than it is worth.
Oct 13, 2014 | Sewing Machines
Hook Drive Gear, Riccar #53741 how to take part off of sewing machine
Today I got such a machine (Riccar) for free from a lady I know. the only problem was that the needle walked against the bobbin (timing problem).
I screwed the sewingmachine open and after some screwing I saw that the part, Hook Drive Gear, Riccar #53741, was broken. Wat I did is I enscrewed two screws wich hold the part on the axe and with a bigger flat screwdriver I could just push the part from the axe, from the other gear. It looks more difficault then it is.
Now I have to get a new part, put it back and time the the machine so that the needle will go normal, at the right time, in the bobbin. Does anybody know the trick to do that?
Apr 23, 2012 | Riccar Sewing Machines
I replaced the rorary hook drive gear and now my machine is out of time
Jan 18, 2011 | Riccar Sewing Machines
Looking for hook gear for riccar eatons viking ezb 108798 and repair manual. my bobbin hook wiil not move
The gear is #53741 and is available at most sewing dealers. The part is also available wholesale at sewing machine services in Canada. Also fits riccar, eatons and babylock machines, so a babylock dealer could help. You will have to beg a repair book or photocopy same to ger mounting and setting instructions. We charge about 60 to install and time the part ONLY.
Jan 16, 2011 | Riccar Sewing Machines
My riccar - model #808 - needs gears. is it possible to have these sent to me?
Yes. However, you wrote "gears" as plural. There is only one gear in that machine; the hook gear. The hook gear is inexpensive and easy to replace and retiming the hook is easy as well. There is another potential problem; the timing belt cogs. They are plastic and, over time, they split, causing the timing belt to jump off time constantly. The replacement kit (2 cogs, belt and idler pulley) is available but is extremely labor intensive and requires a high level of aptitude for mechanical repair.
If you need a hook gear, they are under $10 and can be shipped right to your door. 805-540-9294
Nov 01, 2010 | Riccar Sewing Machines
My hook gear has gone bad, I have singer sewing machine model # 834, I need help with how to take the parts off and replace them
Follow this link, click on the hook gear parts, and you will see a link to a video showing how to install these gears. I was able to follow this video and replace the gears on my old machine. For me it was do-able, but moderately difficult. If you think you're up to it, go for it. Replacing all for gears a t once will cost $50. (Singer 834).
Sep 16, 2010 | Sewing Machines
My Elna automatic TYPE 41C plastic drive gear has shattered. I ned a new gear
You can obtain one of these from, not sure if you mean the cam stack gear or the hook pinon gear down under the rotary hook but both are available, liks are
If you want to install yourself you may want to join the Yahoo group Elna Heirlooms, they share lots of information there on these Swiss made Elnas.
Jun 11, 2010 | Elna 2005 Mechanical Sewing Machine
808 E that I need a diagram for.I think it the hook gear that broke but before i order one I want to make sure thats what it's called
A common problem with the Riccar 808e is a broken hook gear.
The part number is 53741 and usually runs about $15.
Putting it in is easy but then you must re-time the hook. Let me know if you need help with it. I'm not sure where you can get a diagram or a manual...
Aug 21, 2009 | Sewing Machines
Quit working
The 132Q ahs a problem in the hook drive gear ,this is where it is seized up ,happens all the time ,from the back of the machine you can add lubricant to the hook gear and shaft but you will probably have to grab the gear with pliers etc and try to turn it once it loosens up it will be fine ,do not look elsewhere this hook drive shaft is the source of the problem.
Dec 07, 2008 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
343 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
