Question about Cisco WAP200 802.11b/g Wireless Access Point
CISCO WAP200 constantly loses connection
I have a new Brother MFC 9970 printer connected to the WAP. I have the printer set to static IP. After 15 - 20 minutes the connection is lost. If I restart the printer connection is re-established. At first I thought it was the printer and after 3 days of working with (hounding) Brother Tech Support I returned the printer for a new one. Surprise, surprise - same problem so now I suspect the WAP 200G (which I also purchase about 1 month ago).
  • 25 Answers
Your printer is probably going into "sleep" mode after "X" minutes, which may be causing the problem. Use the led interface on the printer to keep it out of sleep mode and that may help.
Posted on Nov 20, 2017
5 Suggested Answers
SOURCE: Dose cisco aironet 1100 support routing
You must use a router to perform NATing to the ISP. Simply use a Netgear or Linksys router and plug your access point into it. You can even use a Netgear or Linksys wireless router with the ethernet ports built into it. Just disable the onboard wireless.
Posted on Aug 04, 2008
  • 53 Answers
SOURCE: Cisco Router Boot Loop
you need to follow the steps to perform a password recovery on the router.
don'y actually perform the password recovery step, but you need to get a uncorrupted copy of the isos installed.
then try again.
I have assumed that when you power on the device you are able to see the boot process in hyperterminal, then just befor you get to type anything the unit reboots.
Posted on Nov 05, 2008
puertobori
  • 7733 Answers
SOURCE: Two of my laptops all
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Feb 01, 2011
SOURCE: I am using Cisco WAP
For that press RESET button it is in the back side of access point hold it for 10 seconds then all settings defaults then reconfigure it again. You can configure it with below method. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Apr 24, 2011
How to connect wap4410 with pc to confgure
Try disconnecting your Cisco Wap4410 from all other network devices then restart it - it will look for a DHCP server, and when it doesn't find one will choose the IP: 192.168.1.245 ---
Set the TCP/IP settings on your laptop to:
IP:192.168.1.250 / Subnet Mask: 255.255.255.0 / Default Gateway: 192.168.1.245 and connect your laptop ONLY to the WAP4410 using a cat5 ethernet cable ---- you should then be able to load a web config page using internet explorer and browsing to: http://192.168.1.245
-------- I've paraphrased the following info from the Cisco User Support Forum (User Juunda):
"...If you read the administrator guide it states that the WAP4410N will search for a DHCP server first, if the dhcp request times out then will it default to 192.168.1.245 this is done so with a user friendly plug and play mentality in mind. Best practice would be to give the AP a static IP of your choice and in your subnet/network so the fastest way to configure the AP out of the box is to assign a static IP on your pc/laptop in the 192.168.1.X /24 and directly connect to the WAP4410N and give the WAP a static IP, define your gateway, DNS servers and then implement it into your network..."
Sep 06, 2013 | Linksys Cisco Small Business WAP4410N...
I need to locate the default IP to my Linksys WAP200. The default has been changed and the owner cant remember what it was changed to. The owner cant afford to lose the configuration settings.
Plug a laptop into just the linksys. Make sure nothing else is connected. Then on the laptop go to start -> run and type cmd. In the black box type ipconfig. This should show you the ip settings on the laptop. There should be one with a default gateway filled in. This will be the lynksys's IP address.
May 31, 2011 | Linksys WAP200 (LS-WAP200) 802.11b/g...
My cisco wap4410n won't let windows 7 connect
Dear Romo
i have had lot's of problem with the WAP 4410N
the usual solution was to reset the Access Point
and in some case you have to reset it to factory default and set it up again try change the channel of change the location of the Access point for testing only
yesterday i face a problem with WAP4410 that the laptop gets IP but smart phone /tablet doesn't connect stack when getting an IP with static IP the devices connected
So what i did ,I went to the market and buy a new AP NOT Cisco brand
Cisco devises i lost truest on it
Abdullah Al-Ahmadi
System and Network Eng.
Mar 26, 2011 | Cisco WAP4410N (WAP4410NLA) Pre80211n...
Brother MFC 8860 has ip conflict. How do I resolve this? The issue is that the IP address is different on my computer versus the printer and thus doesn't allow them to connect. Greg
Each IP-address on a network (private in your home, or public on the Internet) must be unique; hence "IP conflict" when two devices (computers or printers or iPod Touch) try to "claim" the same IP-address.
If you have configured a "static" IP-address into the printer, change it to an IP-address that is *NOT* used on your network.
Or, find the computer on your network that is using the same IP-address as your printer, and change its IP-address and reboot it.
In order to connect, your computer and your computer *MUST* have *DIFFERENT* IP-addresses.
Sep 10, 2009 | Brother MFC-8860DN Printer
I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Mar 02, 2009 | Brother MFC 6490CW InkJet Printer
Brother 8860DN won't work on Cisco switch
Go to the menu settings on the machine itself. Cycle through the options until you find the network settings. Make sure the device has network on and set the connection to DHCP on. save or back out and then restart the machine. It could also be a problem with your Cisco switch and the IP address ranges that the printer and switch have. You may need to specify an address in the printer settings to allow access through the Cisco switch.
Nov 22, 2017 | Brother MFC-8860DN Printer
Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
I went and got static IP addresses from internet provider...Must of caught them on a good day
Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc 665cw connection error
I have a MFC665CW connected wirelessly to a router and a pc connected by ethernet to the router, with a broadband satellite receiver connected to the WAN port of the router (plan to add another PC to the network soon, so have set up the network in advance). I had trouble with the brother status montior flashing 'Ready' then 'Offline' all the time, when I knew the printer was always connected to the network. I had set up the DHCP stuff on the router to allocate IP addresses to everything that connects to the network, like you are supposed to. I updated drivers and firmware, but the problem continued.
When I checked the router status log I saw that one MAC address in the network was making a DHCP request every 5 minutes (i.e. it was asking the router to allocate it an IP address at regular intervals). Every time the router answered that request it made the Brother status monitor go 'offline'. The MAC address was my broadband modem. I fixed the issue by setting the router to allocate a static IP address to the MAC id for my broadband modem (in the DHCP setup section in the router's admin interface). That stopped the dynamic IP address requests from the broadband modem and the Brother status monitor works fine now. I also set static IP adresses for the printer and PC to be on the safe side, although I don't think that matters.
So, check your network log and look for a MAC id that makes regular DHCP requests and then set a static IP address for it. Hope this helps you guys too.
Mar 30, 2008 | Brother Multi-Function Center MFC-665CW...
Printer goes offline
Set IP of printer manually and make sure AutoIP is off. Printout user settings to ensure.
Dec 11, 2007 | Brother MFC-7820N Printer
Network connection lost
search here: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc440cn_all&Cat=8 You may have to change the setting within the printer (see Handbook network).
Sep 26, 2007 | Brother MultiFunction Center MFC-440CN...
Cisco WAP200 802.11b/g Wireless Access Point Logo
133 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
