HP Compaq Presario CQ60 Won't Charge
I have a 4-year-old HP Compaq Presario CQ60. Last night it shut itself down, due to low power, even though the charger was plugged in. Now, when the charger is plugged in the power supply indicator light stays on. When I try to power up the machine, however, the CHARGING light flashes three times, and nothing happens. I have tried just the battery, and just the power cord, and still the same results. What should I do?
  • 47 Answers
Three blinks in a row is the LED code for a memory issue.
Turn the laptop over, remove the panel over the RAM, remove the DIMMs (it will likely have 2 in it), place one in at a time and try powering the system on.
One of the two is likely bad although it is possible (although very unlikely) that both are bad. It should boot up when the good DIMM is in place. Once you have identified the bad one, buy a replacement or possible choose to upgrade the total amount of RAM.
Posted on Jan 04, 2013
Damilare
  • 358 Answers
SOURCE: LG x110 laptop power supply problem:
To be very sure of what the problem is, try to test the your laptop with a another friend's battery, or through a technician first. If it powers, then try and test the laptop again with another AC Adapter, from someone who uses the same type, or a technician.
Trying out these two things will give you a clearer and better idea of what might have gone wrong.
Hope it helps you out.
Posted on Jul 13, 2009
  • 194 Answers
SOURCE: My Compaq Presario CQ60 charger will not charge
try diffrent charger or try to turn on ur laptop with out the battery might be a problem with charger or battery
Posted on Aug 17, 2009
  • 156 Answers
SOURCE: Compaq C500- Will not turn on
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Posted on Oct 23, 2009
  • 218 Answers
SOURCE: compaq presario cq40. when the start button is
Maybe the power supply cable or the charging curcuit on mobo. Can you test the cord with a voltmeter or test light?
Posted on Dec 31, 2009
  • 177 Answers
SOURCE: Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Posted on Mar 07, 2010
Cq60 shut down and restarts itself
Common if backup, windows update, or defrag is scheduled to run at night. Other scheduled operations may use the restart function as well.
Feb 18, 2014 | Compaq Presario CQ60-204NR Notebook
I have a 4-year-old HP Compaq Presario CQ60. Last night it shut itself down, due to low power, even though the charger was plugged in. Now, when the charger is plugged in the power supply indicator light...
It looks as if the LED code would indicate a memory issue. Three blinks in a row.
Jan 04, 2013 | Computers & Internet
Presario cq60-420 won't power on or charge
Is not necessarily a problem of the battery, the screen is also related to, a change in the LCD.This should help you http://www.lcdinverters.net/Laptop-Inverter/Compaq/Compaq.html
Oct 10, 2012 | Compaq Presario CQ60420US Pentium DualCore...
Compaq Presario CQ60 won't turn on
If you already replaced the motherboard then try replacing the power cord. If you meant you replaced the cord already, the it might be your motherboard is bad.
May 15, 2012 | Compaq Presario CQ60-220US PC Laptop
Laptop shuts down when using battery
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 31, 2012 | Compaq Presario Notebook
Compaq Presario Cq6o-211dx Pc Notebook Cannot Turn On- Please Help HP Compaq Presario CQ60-211DX (NB049UAR) PC Notebook microsoft vista basic 32-bit celeron: will not start up please help ! so much...
What you need to do is to pull out the battery from your laptop and put it back after 10 minutes and then turn it on. If still , it was not working the let me know to give u further steps.
Oct 23, 2011 | HP Hewlett Packard Compaq 6720s Laptop...
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
MY cOMPAQ pRESARIO CQ60 fell and cant complete boot
Most likely in this case, the damage is to the hard drive or its connection to the motherboard. The CQ series though has a three point screw attachment for the hard drive so Im more inclined to think that the shock of the landing has damaged the read/write head on the hard drive. If you happen to have another hard drive for a laptop, try installing a new drive and run the installation disc and see if it will complete and boot completely....if it will then the problem was the old drive.
May 23, 2010 | HP Compaq Presario CQ60-249US Notebook
Compaq no power
try any other power socket
Jun 28, 2009 | HP Compaq Presario C700T
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
David Payne
David Payne
