Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer venting
We have a Bosch AXXIS dryer with a blow off vent cap on each side of the dryer. Each of these vent caps will blow off during a dry cycle. I have checked the normal venting and cleaned it out thoroughly to no avail. Any ideas what might be causing this? Thanks.
    President:
  • 1,462 Answers
I think you will find that one of these caps should be off and preferably connected to a vent hose to go outside the house. the reason they are blowing off is that the air has nowhere to go
Posted on Jun 27, 2007
SOURCE:
Dryer doesn't power-on.
Simple answer: way too much dryer lint. Worth cleaning out.
Mar 04, 2018 | Bosch Axxis WTA 3510 Electric Dryer
My Bosch dryer gets hot and tumbles but clothes come out hot yet very damp.
Hi eyecunow115
Check your vent, if your dryer vent hose/pipe is plugged up it will cause the problem you are have.
Also a plugged vent can cause a dryer fire so make sure that the vent is totally free of lint so the heat can get out of the dryer and to the outside Please take time to rate me
Bud
Oct 14, 2012 | Bosch Axxis WTL 5400 Dryer
My bosch gas dryer has a E01 code,would like to known what that is.
It could be a venting problem. Check the lint filter and the vent pipe to make sure they are not clogged with lint. I have heard that greased lighting works well for cleaning the fine lint filter. Also check where the pipe vents and make sure it is clear. Sometimes vent caps have the mesh screens left on them. When cap vents are used the small mesh screen should be removed so any lint that blows through can clear the venting system. I hope this helps. Link for cleaner: http://www.greased-lightning.com/
Apr 21, 2011 | Bosch Dryers
I have a Bosch Axxis WTA 3510 dryer. The dryers heating coil stopped working. While looking on line I was able to fix the problem by using the reset button at the top of the heating coil housing. The...
Hello- The first thing to check, if you haven't already, is how well the dryer is venting. Make sure there are the flexible duct from the dryer to the wall is not crushed or crimped in any way. As well, with the dryer running, go outside and locate where the dryer exits the wall and feel how much air is coming out. Is should be blowing strong out of the vent. If not, and if the ducting travels a long distance through the walls you may want to have a duct cleaning service out. If there is a lot of lint build-up in the vent then the dryer will have trouble evacuating the hot air and the unit can overheat causing the thermostat to trip. If all your venting is ok but the thermostat is still tripping then replace the thermostat. Hope this helps, best regards.
Sep 27, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Why does my bosch dryer wta 2910 only blow cold air?
If the exhaust vent tubes have never been removed and thoroughly cleaned in years this will cause the sensor to keep the heat off in your dryer. If clean the moister sensor is at fault
May 02, 2010 | Bosch Axxis WTA 3500 Dryer
Does the wta3510uf require a vent
If it is a condenser dryer, then no venting is required.
If it is a conventional dryer, then it is adviseable to fit a vent, but not imperative.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Bosch Axxis WTA 3510 Electric Dryer
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
I have an axxis not drying and code F:03 comes up
Most likely your wall vent is restricted. Unhook dryer from wall vent and pull away from wall. If you don't get code your wall vent needs to be cleaned.
If unit still gives code sensor is either bad or theres a restrictions inside machine, likely in the blower wheel hosing. Air flow when running should be strong coming out of vent. many times strength of a blow dryer.
Jul 18, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Rat in dryer vent
You can most likely fet a diagram on sears.com. Go to the parts section and put in your model number and it will let you access diagrams.
Nov 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
222 people viewed this question
Top Bosch Dryers Experts
Elie Balas
Tommmix
Level 1 Expert
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
