I have a 4-year-old HP Compaq Presario CQ60. Last
I have a 4-year-old HP Compaq Presario CQ60. Last night it shut itself down, due to low power, even though the charger was plugged in. Now, when the charger is plugged in the power supply indicator light stays on. When I try to power up the machine, however, the CHARGING light flashes three times, and nothing happens. I have tried just the battery, and just the power cord, and still the same results. What should I do?
  • 47 Answers
It looks as if the LED code would indicate a memory issue. Three blinks in a row.
Turn the laptop over, remove the panel over the RAM, remove the DIMMs (it will likely have 2 in it), place one in at a time and try powering the system on.
One of the two is likely bad although it is possible (although very unlikely) that both are bad. It should boot up when the good DIMM is in place. Once you have identified the bad one, buy a replacement or possible choose to upgrade the total amount of RAM.
Posted on Jan 04, 2013
patemi
  • 366 Answers
SOURCE: I have a toshiba laptop,
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Posted on Jan 04, 2009
SOURCE: my compaq presario v5000 shut down and wont restart
My Presario v5000 is doing the same as above. Except, I let it cool for a little while and it turned on. Now it only turns off after a while. I'm not to sure exactly why that is but i could possibly be an over heating automatic shutdown procedure.
Posted on May 12, 2008
  • 194 Answers
SOURCE: My Compaq Presario CQ60 charger will not charge
try diffrent charger or try to turn on ur laptop with out the battery might be a problem with charger or battery
Posted on Aug 17, 2009
  • 156 Answers
SOURCE: Compaq C500- Will not turn on
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Posted on Oct 23, 2009
  • 177 Answers
SOURCE: Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Posted on Mar 07, 2010
Cq60 shut down and restarts itself
Common if backup, windows update, or defrag is scheduled to run at night. Other scheduled operations may use the restart function as well.
Feb 18, 2014 | Compaq Presario CQ60-204NR Notebook
HP Compaq Presario CQ60 Won't Charge
Three blinks in a row is the LED code for a memory issue.
Jan 04, 2013 | Computers & Internet
Presario cq60 the power will just cut off. it seems like it gets hot very quickly. it says before loading that the internal battery is low. is there another battery other than the one that can come out...
if you flip it over and remove the hard drive cover you will see the internal battery...that needs to be replaced if you are getting that warning.......if its getting hot it possibly needs to just be cleaned out (blown out), yet there is a overheating issue on various HP (Compaq) models where the video chip gets hot and the unit shuts down or has problems booting up
Jul 30, 2011 | Compaq Presario CQ60-220US PC Laptop
My Compaq laptop just immediatly turned off last night making a small sound and the screen went off, i thought it could be due to the laptop over heating so i let it cool down for a couple of hours, when i...
Hi
Thank you for your query
Please can you try the following
Remove the battery
Remove the charger
Press and hold the power button in for 30 seconds
Plug battery and charger back in
Retry powering laptop
You mention it made a noise if it was like a buzzing or fizzlin noise it is likely that the jack on the motherboard may need replacing this is relativley inexpensive to do and a reputable repair shop will be able to help
Regards
Shauqat
Nov 23, 2010 | Compaq Presario CQ60-220US PC Laptop
I have been using presario CQ50 compaq laptop, it was working fine but as time went on the laptop felt as though it was starting to overheat and would randomly turn off, i wasnt sure if maybe it was the...
are you going to spend hard cash on this junk
its old and worth Zero
now
try a new battery, oops those are expensive.
i see working
presario CQ50
for $30 working
not working worth nothing
its worth at best the cost of potted plant.
why fool with it>? or spend cash on any COMPAQ.?
got to "GOODwill" fine a 10 year or newer system.
best advice of all that. one that works too.
Mar 28, 2017 | HP Compaq Presario 730US Notebook
Compaq C500- Will not turn on no lights except for battery LED lit. It was working fine last night. The computer was left on and the battery ran down so it did not shut down correctly. When i push the...
Oct 22, 2009 | HP Compaq Presario C500t Notebook
Aug 16, 2009 | HP Compaq Presario CQ60-249US Notebook
Compaq no power
try any other power socket
Jun 28, 2009 | HP Compaq Presario C700T
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
My compaq presario just shuts down. When I go to
Typical reasons could be overheating and or the charger is on it's last legs. Do you have the same problems when you're using the computer with battery alone. Does the laptop feel hot?
The reason the charger is getting hot is because it's probably a 65W charger and not a 90W (that's just a guess though)
Let me know if I'm right or not.
Feb 21, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
