Question about Sony KV-27S36 27" TV
No Picture, Sound Fine
Suddenly I lost the picture. Sound is fine. The remote changes channel and seems to work correctly. On TV the 'Standby/Timer light is flashing. Nothing on the remote seems to get the picture back. I would appreciate any suggestions. John Carson
  • Kennard Dec 17, 2007
    Two loss of picture conditions observed when Sony KV-27S36 is turned on :
    1) Good full Picture on for approximately 2 seconds, then for 1 second the top 1/2 of raster is visible on screen, then dim full screen for 1 second, then dark screen. TV Channel sound is heard. After this condition there is NO blinking light.
    2) When TV is turn on initially there is a dark screen. TV Channel sound is heard. Light is blinking continuously.
    Diagnosis:
    A) Checked for cold solder joints and touched up any that looked questionable. All looked very good. No change in loss of picture.
    B) Confirmed voltage on G board CN641 at pin 1 is 135 Vdc. Did not change during start up or after a few minutes.
    I would appreciate any suggestions to fix this problem. Jim
    New Friend:
  • 15 Answers
Check the connection at the back between the mainboard and CRT board or small tube board! It have 1 missing voltage 200v (or screen adjustment) check all resistors in G2!
Posted on Feb 14, 2010
  • 432 Answers
Hey John, How many times does the light blink? No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. One blink - not used for the self-diagnosis Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. I suggest you do a hard reset. Unplug the power cord for 4 hours. Then plug it back in and check it. If it works, great. It not, cost of repair for this is usually around $150 - $250 plus the house call.
Posted on Jun 26, 2007
SOURCE:
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Someone sat on the remote control for my Yamaha rx v557 and I have no tv picture--do have sound. System is set up to Direct TV. I can change channels and hear everything fine, but can't get a TV picture It...
If it was the remote that changed the function then likely the mode has been changed. You probably need to have it changed back to the input you plugged your DirectTv into, such as video1 or component, or cable/sat. etc, etc...
Dec 14, 2009 | Yamaha RX-V557 Receiver
Sony tv model # kv36fs320 no picture sound is there. Standby timer red light flashes 5 times.
The power seems ok as it was working fine this morning had kids channel on for my daughter for about 1-2 hours while I was pottering about cleaning then daughter told me TV had gone black
May 15, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture but no sound
press mute button on tv remote
Oct 20, 2008 | Zenith B27A11Z 27" TV
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
I have picture and sound when I watch a dvd/video but not through cable.
Try turning off the dvd/vcr and put your tv on the output channel of your DirectTv receiver. If this doesn't work it may not be hooked up correctly.
Oct 20, 2007 | Durabrand DU1301 TV
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
240 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
