Question about Harbinger HA120 Portable PA System
Not getting enough volume out of PA system
Out of nowhere I stopped getting power out of my PA. No idea what the problem is. I can get a little volume but I have to crank it to 11 in order to get anything that I can hear, then it distorts. I've tried unplugging everything but still can't get hardly any sound.
2 Suggested Answers
  • 5603 Answers
SOURCE: I have the Harbinger HA120
You need to do some test on the equipment. First check the resistance of each speaker. You may have a bad cable... and yes you can destroy the speakers with too loud a signal... HOWEVER if the system is made to work together this is USUALLY not a problem.
Posted on Aug 26, 2011
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
Power light is on but no speaker output?
Disassemble it enough to get to the speaker to check for continuity. If it's blown, replace it, If not, the amp board is probably blown and needs to go in for repair.
Mar 08, 2016 | Behringer Eurolive B205D Active 150-Watt...
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
Using Boss FV 50H between output of Tascam M-216 mixer and church PA (line input of main mixer) with microphones on 1 channel and guitars on other. Problem:Quite a loud "pop" or...
The problem is you have an ILLEGAL connection based on proper electronic design. This pedal has UNBALANCED high impedance interconnects and the output of your mixer and the PA SHOULD be BALANCED low impedance interconnects. This makes the system subject to noise and you may even get static discharge noise. Also verify that the TASCAM and the PA system are ALL powered from the SAME receptacle or power conditioning module. This is a tough design problem to achieve what you want. Essentially you want to make the master gain of the TASCAM on a foot pedal as I understand it. There is one pedal that CLAIMS to have balanced in and out and if I had the schematic I could verify it... but I could not find the schematic in my searches... look at: http://www.sweetwater.com/store/detail/StealthPedal
This one MIGHT do the job right. You MUST use TRS BALANCED cables, NOT TS, from the mixer to this and from this to the PA. Do research on BALANCED and UNBALANCED and TRS and TS and also XLR cables using google to understand the difference and importance of using balanced interconnections in your system. I would try to get one of these pedals on approval with the correct cables and test it.
Sep 18, 2011 | Roland Boss Fv-50h Stereo Volume Pedal...
I have a Eupoport EPA 900 system. Recently I started getting a consistent, low pitch and fairly loud hum out of both speakers. The hum adjusts with the volume, and I have tested it with various working...
Is the hum there with NO input cables connected? If not, you have bad cabling. Make sure you use only XLR to XLR mic cables and not the junky ones with a 1/4 inch plug that are for Karaoke machines. These devices usually use switching power supplies and do not have the power supply originating hum of older equipment. If the volume control adjusts the hum, then the hum originates previous to the control which is either in the preamps or the external inputs.
Aug 25, 2011 | Behringer Europort EPA900 Ultra compact...
Hi, I have a new Peavey Escort 3000 PA, more than happy with it, however in the last few sessions, including a gig today, the sound cuts out completely and the green LED on the unit just flickers. I...
It sounds like the power supply is overheating, or an interconnect is becoming loose due to excess heat. This might be due to a faulty heat sensor, but counter-intuitively could also be due to a low voltage supply, that is, drawing more power than the circuit can handle so the voltage drops. Please check that the outlet(s) you are plugging in to are rated to supply enough power.
Aug 29, 2017 | Peavey Escort 3000 300 Watt Portable PA...
Hi I run a Super Sonic 22 which for me has a sweet spot at 2-3 Volume on the burn channel. I need to run at 4-5 on stage but at this settin it looses the full quality and goes very mushy just like the...
It just doesn't have enough power for what you want. Either get a bigger version amp OR mic it and run it into the PA system where hopefully you have enough power.
Jun 03, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
Sound is distorted at certain frequency / volume what would cause this?
More infornation is required to provide a real answer, but I can give you a few possibilities:
1) There is a problem within the feedback loop that is allowing some frequencies through. This will be more prevelant at higher volume levels.
2) If there is a tube pre-amp section, the tube can be "microphonic". This too is generally more likely at higher volume levels.
3) Defective components in the amp section. These may pass some DC voltages that will sound like distortion.
If you can, please experiment a little to try to find when the problem is most obvious. With more details about when the problem occurs may give us enough info to determine the cause. Otherwise a trip to a service shop that has access to test equipment will be required.
Dan
May 21, 2011 | Behringer K3000fx 300w 4-channel PA...
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Harbinger HA120 Portable PA System Logo
54 people viewed this question
Top Harbinger Music Experts
Michial Gueffroy
Are you a Harbinger Music Expert? Answer questions, earn points and help others
