Question about Panasonic DVD-S29 DVD Player
DVD player wont show on screen
I was going through the settings of the dvd player, and i pressed something and now whenever it plays a dvd its in black and white and the screen is basically just screwed, you cant see a thing. And even if i get the menu back up, you cant see it because it looks the same on the screen. I was just wondering if you could tell me what steps I could take to fix the problem or email me the manual as I have lost mine. Thanks Ben.
  • 84 Answers
You can reset the dvd player back to the original settings by doing the following: While stopped, press and hold [QUICK OSD] [DVD-S29] or [ADVANCED DISC REVIEW] [DVD-S26] and [PAUSE] on the unit and then also press and hold [< OPEN/CLOSE] on the unit until ?Initialized? disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Posted on Jun 26, 2007
SOURCE:
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
My DVD says "root" on the screen. What do I do to get it to play?
"Root" is part of the Menu screen, press Menu on the remote to clear it.
Jun 05, 2010 | Philips Magnavox DVD/VCR Dual Player
My dvd player pdv 709 wont show the movie .it shows half
my Portable DVD Player just stop playing movies. i put a movie on and it want read or it will start the movie snd just stop and want play no more
Oct 23, 2009 | Durabrand PDV-709
Mine wont play anything a DVD it recorded it wont let me finalize
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jul 07, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Jensens VM 9312 car DVD player problem
Just go to the set up menu ( Your screen should say setup at the upper center of your screen ) Then press 5, 4, 3, 2, 1, 0 with your remote control and a second menu will apear, on your left side press the second option and select parking bypass to on.
Sep 03, 2008 | Jensen's VM9312 Car DVD Player
DVD & VCR Recorder Model ZV450MW8A
My grandmother had the same problem. Whenever you press "timer set" to set the timer, it automatically turns off the VCR and whenever you turn it back on the VCR is locked and it's stuck on DVD. All you have to do is press "timer set" to unlock the VCR side. Then you may have to press "VCR" to switch it back. Hope this helps.
Jul 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Region codes
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
Nov 11, 2007 | Televison & Video
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Panasonic DVD-S29 DVD Player Logo
127 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
