Question about Frigidaire ATF6000ES Front Load Washer
What does e40 mean on a frigidaire washer - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello plauano - Typically error code E40 indicates that the washer has detected a door switch or main control board problem. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes (this usually clear most false error codes). If it proves to be ineffective contact a professional to move forward accurately.
Posted on Jan 08, 2013
Built in machine. It show error e40. What does it meant
Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of “E40”. I am showing that an “E40” error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
Mar 23, 2016 | Electrolux Washing Machines
What does e40 mean
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected
Jan 30, 2015 | Tricity Bendix WDR1040W Front Load Washer...
WHAT IS ERROR E40 MEAN?
Its a defective door lock. It might have to be replaced by a techie! Hope its under warranty
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
I have a GLTF2940ES frigidaire washer. I ran it on permanent press to check water level. Paused it and checked it. changed setting to drain and spin. Now when i press start, the lights go out, and no...
Good Morning Aaron - Based on the symptoms you are describing and if you are receiving an error code E40, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging the unit or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your unit's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Jul 25, 2013 | Frigidaire GLTF2940ES Front Load Washer
What does E40 mean?
Here's the repair manual for your model: manuals...asher_2004.pdf
There is a test chart in the troubleshooting section you can follow. Test#7 on page 62 talks about the door latch/lock, it asks if your door strike is broken, I've seen a few break before myself.
If you replaced the door latch assembly and its still doing it, and the door strike isn't broken then it said your control board is the culprit.
Hope helps.
Sep 19, 2011 | Frigidaire GLTF2940ES Front Load Washer
My electrolux washer dryer ewx14540w keeps flashing e40 and won't do anything, please help
Hi dear.Related to your problem,E40 means:
• The door is not firmly closed. (E40)
• The machine is not plugged in or there is no power
at the socket.
• The main fuse has blown.
• The type of fabric has not been selected by means of
the relevant selector dial.
• The Start/Pause button has not been depressed.
• The Delay Start option has been selected
Please checked those followings.I hope that helps.Thanks.
Feb 13, 2011 | Electrolux EW1209i Front Load Washer /...
Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Nov 14, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Oct 03, 2008 | Zanussi FJS1225W Front Load Washer
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Frigidaire ATF6000ES Front Load Washer Logo
162 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
