Question about Microsoft Xbox 360 Console
Error e 73
My xbos 360 , can't be played is got one red light a error e 73.
any help with this please??????
  • james morgan
    james morgan May 11, 2010
    for this fix you need to strip the console and take the case off, then unplug the fan and turn the 360 on, leave it for a while till it gets hot then turn off, plug fan back in and let it cool then try again. if it still does not repair it then you might have to strip the mainboard out and go over it with a heatgun. even though this error is reported to be something to do with the ethernet port i find that doing the heatgum trick has fixed the majority.
    Sergeant:
    Champion:
  • 378 Answers
Do not ever use a heatgun on your system it will damage the mainboard and if it melts the solder under the GPU you will need to send it out to get the chips removed and reflowed which is probably more then getting a new one.
Posted on Jan 19, 2009
It has red light on the front and the screen says error 73
here is a webpage with some tips http://www.360errorcodes.com/xbox-360-error-73
also i you want to get it repaired go to craigslist.com and search up xbox repair
Jul 28, 2011 | Microsoft Xbox 360 Console
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
Red flashing light in bottom right hand corner of xbox 360 arcade console. Says System Error contact customer support error code E 73.
the best thing to do is to contact the customer support because there are many occasions on which it can show you this message and you can't be sure which is which.
hope dis helped you?please rate
Dec 16, 2010 | Microsoft XBOX 360 ARCADE Console
I have one red light on my xbox 360 elite with code E 73
https://www.yousendit.com/download/THE2b3BORkUrV3lGa1E9PQ.
hope this helps its two ebooks on how to repair red light error ,full instution plus pics show u how.this download is only there for 7 days or 100 downloads.DT
Feb 23, 2010 | Microsoft Xbox 360 Elite Console - Black
3 red flashing lights on xbox360
General Hardware Failure
usually caused by the E-73 Error from defective X-Clamps/Heatsinks
Feb 07, 2010 | Microsoft Premium System for Xbox 360
I have an one red light problem and error 73. Don't use ethernet
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm This should help you, I repaire these all the time and as soon as you get rid of those x-clamos and use the screw and washer set it fixes this problem. My name is Tim Ehrhart and I hope this helps you
Mar 15, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
My xbox can play older games but not new ones
If the xbos 360 is a pro it will not play all rugular x-box games...not sure bout the elite...and the arcade can play none
Dec 25, 2008 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Error
You probably have a general protection error. Call microsoft's tech center. They can tell you what the code means and if you need to send in the console for repairs. Since they extended the warranty on the system, most repairs should be free.
May 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
52 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
