Question about Stanley Pci109 100 Watt Inverter With Installation Adaptor
How do I replace the fuse in a PCI109 100w Inverter?
I blew the fuse on this product and I cannot find the fuse in it. It says to remove the brass cone cap and that is all!
I have a Panasonic inverter microwave. Was working perfectly an hour ago. Now totally dead. There is no light or anything. Have checked plug and fuses. No smell or anything. Can you please help.
Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
Jun 20, 2017 | Panasonic Microwave Ovens
I have a durite 1500 watt inverter and it has stopped working is there a fuse inside ?and if so how do i change it
Could be a number of reasons it quit. You crossed the power wires blowing the diodes for protection, or you over loaded it an blew a MOSFET, the fuse blew, or a number of things. You have got to be more specific.
May 07, 2017 | Inverter Electronics - Others
Hooked my inverter backwards so blew fuse how do I fix my inverter?
If the inverter does not have reverse polarity protection, there may be a few components on the circuit board that may need replacing. If replacing the fuse didn't fix it, then you'll have to seek a repair center from the manufacturer's website or from information from the owners manual.
Oct 01, 2016 | Cars & Trucks
I am looking for the parking lite fuse on 1992 geo metro conv
that means there is short in the park lamp feed.
its the largest feed on all cars, and very hard to find, if visuals of harness show no damage, and you remove all 4 tail and front light bulbs. the light blubs with brass (yellow) metal bases, LOVE to short.
remove all 4 and try new fuse.
http://www.fixkick.com/power-elect/blows-fuse.html
all ways to find a short are there ,even Duanes video.
Jul 08, 2014 | 1992 Geo Metro
I lost my picture n all I see is a black screen. What could the poblem be and is it fix able.
hi,
Is there is any light in the screen. If not, then Backlight inverter is faulty. All lcd tv have backlight to light the pixels. If you watch the screen very near then you will be able to see image on the screen. First of all check is there is any budged capacitors in the power supply. If there then replace it will solve the problem. If no then check the inverter board. Do on thing check the fuse in the inverter board. If the fuse is faulty then replace it. If the fuse blews again then the inverter board is short you have to replace invereter baord. It is not possible to repair the backlight inverter. You have to replace the board with a new one.Have added the picture of inverter board and budge capacitor for your reference. If you need any more assistance feel free to contact me by Fixya
ajin_g_82.jpg ok
Sep 07, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Lcd television has sound but no picture wat could be the problem in the circuitry.is it the lcd
hi,
. Is there is any light in the screen. If not, then Backlight inverter is faulty. All lcd tv have backlight to light the pixels. If you watch the screen very near then you will be able to see image on the screen. First of all check is there is any budged capacitors in the power supply. If there then replace it will solve the problem. If no then check the inverter board. Do on thing check the fuse in the inverter board. If the fuse is faulty then replace it. If the fuse blews again then the inverter board is short you have to replace invereter baord. It is not possible to repair the backlight inverter. You have to replace the board with a new one.Have added the picture of inverter board and budge capacitor for your reference. If you need any more assistance feel free to contact me by Fixya
Aug 23, 2011 | Televison & Video
Power light comes on but nothing on the screen.I am in Ballito South Africa
hi,
Is there is sound on your tv. Is there is any light in the screen. If not, then Backlight inverter is faulty. All lcd tv have backlight to light the pixels. If you watch the screen very near then you will be able to see image on the screen. First of all check is there is any budged capacitors in the power supply. If there then replace it will solve the problem. If no then check the inverter board. Do on thing check the fuse in the inverter board. If the fuse is faulty then replace it. If the fuse blews again then the inverter board is short you have to replace invereter baord. It is not possible to repair the backlight inverter. You have to replace the board with a new one.Have added the picture of inverter board and budge capacitor for your reference. If you need any more assistance feel free to contact me by Fixya.
OK
Aug 21, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
I have a sylvania 110 voltage and was used in a 220 voltge extension wire. Can it be repaired?
Either you got lucky and just the few blew inside. Or worst case is the power inverter blew and will have to be replaced. You can test the inverter with a voltmeter. You can look at the glass bus fuse itself to see if it is bad or not.
Sep 02, 2010 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
2000 Pontiac Sunfire heater fan not blowing. I took it to the mechanic and he replaced the resistor and it worked for 2 days and then blew the 30amp fuse. He said he then removed the blower completely and...
About the only thing left that hasn't been replaced is the fan control switch itself; it may have disintegrated internally. You didn't mention if the fan motor itself had been replaced but I assume it was not in the system when the fuse blew again.
Not on GM products, but I have replaced a power connector that had (because of lousy internal contact) melted and allowed a ground contact to come into contact with a 12 volt line.
Feb 17, 2010 | Pontiac Sunfire Cars & Trucks
Stanley Pci109 100 Watt Inverter With Installation Adaptor Logo
50 people viewed this question
Top Stanley Electronics - Others Experts
Are you a Stanley Electronics - Other Expert? Answer questions, earn points and help others
