Question about Kenmore Dishwashers
Dishwasher door hangs too low - Kenmore Dishwashers
  • Kenmore Master
  • 3,247 Answers
Usually a problem with the springs attached to the door.
If you can provide a model number I could try and find the readjustment procedure. A small screw on the top of panel is usually involved, but need to be sure.
Posted on Jan 04, 2013
  • sblum99
    sblum99 Jan 05, 2013
    Sam it is Model number 587.15103801 Kenmore. Thanks
  • Sam Jan 06, 2013
    I would suggest looking at the information available onhttp://www.partselect.com/PS972325-Whirl... to help fix the problem. The location of the springs is available athttp://www.searspartsdirect.com/partsdir...
Door latch stays down and will not allow the door to close
sound like the litle robe on the door latch has stretched
Feb 05, 2014 | Whirlpool Dishwashers
My Dishwasher door has suddenly become very heavy, there is a cord hanging down on left hand side its a HJA8630 about 5 years old can you help
The cord you refer to is part of the door spring assembly, you need to take off the bottom panel and repair or replace the door spring or cable.
Jun 04, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
Door wont close
open the door now look to see if the screws holding the dishwasher in place have worked loose and are hanging down preventing the door to close. On the underside of the counter top
Mar 12, 2011 | Dishwashers
Install awooden panel on miele g2183 dishwasher it cover the latch how do open the dishwasher
you either have an over hang on the panel to grip hold of and open the door or you fit a handle to the integrated dishwashers.
Jul 23, 2010 | Miele G2183SCSF Builtin Dishwasher
Door is hanging down to floor.
Change the damper on both the sides. Dampers are hydraulically controlled with a spring. It is similar to the shock absorbers in automobiles. Similar dampers can be observed in car rear wind screen door also. (dickey door). Replace it as a set.
May 24, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
My door will not close so that I can start the dishwasher
sometimes the mounting screws will work loose and not allow the door to shut.Open the door now look where the top of the door hits and see if the two mounting screws have worked loose and hanging down re-tighten
May 16, 2010 | Jenn-Air 24 in. JDB1090A Built-in...
Soap dispenser will not open during cycle
I have the same dishwasher, have for about 2 years. It took me about a month to figure this out... But, you cannot run it with the flatware rack hanging on the bottom dish rack, you have to move it to hang on the door and you cannot have anything in the compartment under the soap dispenser that is tall enough to block it from opening. Annoying design for sure!
May 12, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Dishwasher door leaks
If the dishwasher is built-in check to make sure the door is closing all the way and not hanging up on the side cabinet near top of door. If the door is closing properly then inspect the door gasket for cracks, tears, areas that the seal needs seated back in slots, and any debris. If it is damaged in any way a new door gasket seal needs to be installed. www.selectparts.com should have the seal you need at a great price.
May 02, 2010 | Dishwashers
I have a 1.5 over the range fridgidaire microwave...it seems the door hangs a little low because in order for it to work you have to put your thumb on the bottom of the door to raise it up a little and...
Does it seem to hang low or does it actually hang low? Readjust it. There is a switch that may hang high when the door closes. You just have look at what does what and what ain' doing what it is supposed to. first.
May 04, 2009 | Frigidaire Over-the-Range Microwave
Failing door latches
Misaligned door. To much weight on door. Someone, maybe a child, hanging on door when opened.
Dec 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwashers Logo
124 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
