Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Anonymous Posted on Jan 03, 2013
Dishwasher dishes cloudy and makes loud buzzing soundf
Our fairly new dishwasher is making a loud buzzing sound and is not cleaning the dishes. There is a cloudy film on the glasses and dishes?
Mike
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 677 Answers
  • Posted on Feb 18, 2013
Mike
Expert
Level 2:
Prodigy:
Answers
677
Questions
0
Helped
366287
Points
782
I am not sure about the buzzing but cloudy dishes is caused by
hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jul 05, 2008
SOURCE: washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Anonymous
  • 95 Answers
  • Posted on Jul 08, 2008
SOURCE: whirlpool dishwasher
It sounds as if your motor is locking up. Check under the front lower panel, snd see if there is water leaking into the motor, the motor simply seizes, and needs aspot of grease. You may also need to reprime the washer. To prime, Slowly advance the timer at start-up, After a few clicks, you will here the water valve open and start to fill the tub, then let the washer do it's thing.
Anonymous
  • 82 Answers
  • Posted on Oct 05, 2009
SOURCE: whirlpool cabrio-buzzing noise when water runs
i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
Anonymous
  • 262 Answers
  • Posted on Jan 15, 2010
SOURCE: dryer has started to make a loud sqealing when it starts
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Anonymous
  • 600 Answers
  • Posted on Jun 15, 2011
SOURCE: I have a Whirlpool DWH B00 dishwasher and the
Hello, Thank You for using FixYa. I will be helping you today.Start by running a bottle of dishwasher magic through it and make sure the drain line is clear.
Thank You and please rate my answer if it was helpful..
2answers
Why does my (countertop) dishwasher make a loud buzzing sound during its wash cycle
When the drain motor turns on for a Danby dishwasher, it sounds like a buzzer. This is normal
3helpful
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
4helpful
2answers
Glasses dirty looking and cloudy after wash cycle.
If there is not enough water, the dishes will not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film, or cloudy look after the wash cycle.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Nov 16, 2009 • Dishwashers
2helpful
2answers
My dishwasher is now leaving my dishes cloudy. What causes this?
Make sure that the rinse-aid(jet dry) container is full. If it is full have you noticed if it's level has not dropped. It is possible that the rinse-aid dispenser is plugged. This will cause the dishes to be cloudy. You can also try running the dishwaher empty and add a cup of vinegar to the bottom before your start. There is also this stuff called "dishwasher magic" that you can try running in the dishwasher to clean it. Try using a soap with the rinse-aid in it or install a basket with a rinse-aid tablet and see if that helps clear up those cloudy dishes.
2helpful
2answers
Cloudy Dishes - tried different detergents and not much change
Check the following to address this issue you are having..
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, I recommend a solution called Dishwasher Magic.
Dwc7400aaw maytag -glass are cloudy,groundup food particles drying to dishes & glasses,when filling makes loud high pitched sound-generally not cleaning well.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Kenmore elite dishwasher making loud buzzing sound when washing
it sounds like a broken empellar in the pump like there is a piece of it broken off and ratteling around in there... change the empellar
Feb 21, 2009 • Dishwashers
2answers
Dishwasher
Go to www.dishwasherfilter.com and have sparkling clean dishes with no film or spots, every time!!!
Make sure you use promo code DF5150 to get an additional discount!
1helpful
Dirty dishwasher
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
