Question about Locks & Locksmithing
PROGRAM Brinks keyless deadbolt Model No.: 4303-119-2
2 Suggested Answers
SOURCE: i have a kwikset deadbolt
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Posted on Sep 30, 2011
Where do i find the english instructions for installing Garrison keyless entry deadbolt lock? 046-2667-4. Got only french in box
Is this model sold in the USA or Canada? If not then you may have a problem getting the booklet in English. You could post the instructions and then use google to translate them.
Aug 12, 2016 | Deadbolt Locks & Locksmithing
How do I remove a brinks deadbolk lock from door
1. Open the door.
2. Unscrew the 2 screws on the inside and the 2 screws on the edge of the door.
3. Pull the thumb turn off, pull the outside cylinder and ring off, and pull the deadbolt assembly out of the edge of the door.
4. Unscrew the strike plate from the door frame and remove it and the plastic thing behind it, if it was installed.
5. Throw the whole thing in the trash. I wouldn't even reuse the screws!
Feb 18, 2015 | Brinks Combo Pack Deadbolt & Keyed Entry...
Wher can i get program manual for facto electroni deadbolt
Log onto the manufacturers website and you should be able to find the user manual for download or on screen viewing.
You will need to know your specific lock in order to find the correct manual.
Jan 08, 2015 | Deadbolt Locks & Locksmithing
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
I have a touchpad Zurich deadbolt lock on a front door. No manual. I replaced all 4 batteries at once. How do I re-program or re-set the passcode? Gordon
I have been searched unsuccessfully for "Zurich deadbolt keyless remote" in order to help you. However, if the picture shown in your request is accurate for your lock, I have found some information which may be useful to you!
The brand that I found is Lockstate, which looks like the lockset pictured. Go to this webpage (copy & paste into your browser search window):
http://www.lockstate.com/manuals-and-downloads.html?start=10
Go to the bottom of that page, to "LOCK LS-DBS" and click on Download. This will download a PDF file of the installation and programming instructions.
If you cannot open and view the download, you will need to download and install Adobe Reader. You can get it here:
http://get.adobe.com/reader/
If this is not the correct information for your lock, please re-submit the problem and I'll try again. Any further model info, etc., will be helpful.
Good luck--and please provide feedback if this helps!
Aug 25, 2011 | Deadbolt Zurich Digital Keyless Remote...
I need to change my code on a kwikset model 907-l03 asap
Take the cover off on the inside.
A push the program button
B enter the desired 4-8 digit code
C push the lock button to set your code
D enter your code to insure it retracts the deadbolt
To enter a second code push the program button twice and repeat steps B thru D
Jan 24, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Locks & Locksmithing Logo
1,401 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
