Question about Samsung Televison & Video
Samsung 40" LED TV - UA40D5003BR - TV switches itself off when operating via HDMI cable.
PVR and Blu-ray plugged into AV receiver via RCA cables. AV Receiver Output (only 1) connected to TV.TV works perfectly with RCA cables. But, when connecting HDMI cables, TV switches itself off (and on) when operating PVR and Samsung AV receiver via HDMI cable/port. Blu-ray works perfectly when standalone HDMI - TV perfect. PVR does not work on stand alone HDMI - switches TV off after 1 or 2 minutes, restarts and cycle continues. Blu-ray and PVR switches off and on when working through AV receiver.
SOURCE: connecting blu ray to surround sound receiver to tv
Hi, I have just completed this installation myself.
You are correct, HDMI to Amp Input from Bluray and then HDMI from Amp output to TV. Coloured cables are not required to operate the bluray now.
Good luck
Posted on Jan 08, 2009
satavlad
  • 405 Answers
SOURCE: HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Posted on Nov 28, 2009
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
SOURCE: Digital Audio cutting out
I have this problem also with my older yamaha receiver with both digital outputs on the DCX3200 (spdif and coaxial)
very anoying ! The cable company replaced my DCX3200 with a new one. still the same problem !
Posted on Jun 03, 2010
SOURCE: Just purchased a new samsung blu ray player with
onkyo receivers have a problem, see
http://www.hdtvsupply.com/hdmi-cable-booster.html
Posted on Jul 06, 2010
How I can connect my Samsung Home Theatre System ( 7-1 channels AV receiver) using the HDMI V 1.4 3D cables to connect them to to my LG 55 LX 9500 3D HDTV LED TV . The equipments are :( LG Blu Ray...
ideally you would simply add an hdmi source from each device to the surround receiver and send the output to the tv but im thinking your amp may be short on inputs from all devices and if indeed it was this simple you wouldnt be here seeking this info also note you may be able to use the output on the set to gain another signal tranfer but note there can be compatability issues on some sets whether they will decode hdmi in and rca out or optical out like i said some sets ok :) i wish you luck and wishin i had this all in front of me so i could be a greater help any q's drop me a comment here ok :)
Feb 26, 2011 | LG Televison & Video
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
Sony VPL-HS10 Please check Digital signal sel.
your projector might not be able to take this resolution
Jan 30, 2010 | Sony VPL HS10 Multimedia Projector
I need help setting up the cables on my home theater system. I have: 3 HDMI cables 1 Coaxial cable Yamaha 6250 receiver Samsung 7000 series LCD tv Samsung Blu Ray player Shaw Digital cable PVR box (similar...
2 hdmi inputs on samsung tv? different ways you can do it.if it was me i would run samsung blue ray to tv hdmi in,shaw box [if supported hdmi]to tv in, if not coax.
and i would sound out on tv to yamaha?
Dec 20, 2009 | Yamaha HTR-6130 Receiver
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
Sony DVP-NS77H No outout
I had the same problem unitl I read the manual a little more carefully.
I found that ALL connections through my AV receiver had to be identical. I was using component connections with analog connections.
Since I switched to all HDMI connections (cable box to AV receiver, DVD to AV receiver and AV receiver to TV) all is fine.
Hope this helps.
Mar 16, 2008 | Televison & Video
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
