Grundfus pump wont power the cu 200 sq flex lights up f3
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
Nov 16, 2016 | Office Equipment & Supplies
Bought the new version of the jacuzzi1.5hpLRC motor. The hook up to the pump is on top instead of the side. Is there tubing we can use to connect the two?
Unless there is a proprietary hook-up ( i coundnt find one) the best thing would be to plumb it in with pvc. They do have Flex PVC pipe but I've never used or heard anything about it so use at your own risk.
Jun 17, 2015 | Jacuzzi Avalanche 60 Sq. Ft. D.E. Filter...
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
Why does Grundfus bell pump dry runs won't turn off?
If you have a switch of some sort to tell the pump the house needs water, look there first.
Aug 29, 2014 | Plumbing
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
How do you calculate cfm for a room when sizing a hvac system fr a residential
their is a chart that homedepot use to give in a/c dept may still be their but a 6" run is about 100 cfm this will cover 10x10 1 sq inch is 1 cfm 1 ton is 400 cfm a gas system is 400 per ton and a heat pump is more like 425 but is best to figure the 400 cfm for both say you got 12x10 room that is 120 sq ft so you need around 120 cfm and if the 6" duct is 100% hard pipe with no flex you can get that if you balance your air if more help is needed email pendletonheatandair@hotmail.com please give me a vote and rating
Sep 22, 2010 | Cfm Heating & Cooling
Kenmore model 795.7500401 need to know cu sq ft
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Aug 27, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
8 inch woofer blown need specs...OHM, Impedence and wattage
John,
Checkout JL Audio's 8" subs I'll leave specs at the bottom, if you want to look around for something cheaper check out this install I did on a Jaguar X-Type. The sub here is a good example of a free air application and you can look for a sub with the same features. Keep in mind however this setup is using a high power Coustic 10" sub and you only need to handle the stock amp- 25 watts. So you may not need such a beefy sub, but something close would be good. If your sub uses a small enclosure go with something like the JL listed below. Good luck and let me know if you need anything else.7a2e6d4.jpg -Dynami
12855.jpg Reviews W1v2 Technologies Recommended Power Chart Tutorials 12856.jpg 8W1v2 DRIVER SPECIFICATIONS 8W1v2-4 8W1v2-8 buyitnow.jpg buyitnow.jpg Free Air Resonance (Fs): 34.55 Hz 36.60 Hz Electrical “Q” (Qes): 0.508 0.612 Mechanical “Q” (Qms): 6.260 6.000 Total Speaker “Q” (Qts): 0.470 0.555 Equivalent Compliance (Vas): 0.66 cu. ft. / 18.801 liters 0.63 cu. ft. / 17.87 liters One-Way, Linear Excursion (Xmax)*: 0.3 in. / 7.6 mm 0.3 in. / 7.6 mm Reference Efficiency (no): Efficiency (1W/1m)**: 83.86 dB SPL 83.58 dB SPL Effective Piston Area (Sd): 32.67 sq. in. / 0.0211 sq. m. 32.67 sq. in. / 0.0211 sq. m. DC Resistance (Re): 4.00 ohm 7.84 ohm Nominal Impedance (Znom): 4 ohm 8 ohm Thermal Power Handling (Pt): 150W 150W Driver Displacement: 0.02 cu. ft. / 0.571 liters 0.02 cu. ft. / 0.571 liters Net Weight: 6.3 lbs. / 2.9 kg 6.3 lbs. / 2.9 kg * Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied.
** Efficiency (1W/1m) is not an accurate indicator of a subwoofer’s output capability and should not be used as a comparison to other subwoofers to determine which one is “louder”.
acrobat.gif Click here to download the owner's manual (PDF). Click Here For Recommended Enclosure Specifications 8W1v2 DRIVER PHYSICAL SPECIFICATIONS
12819.jpg Nominal
Diameter
Overall
Diameter (A) Mounting Hole
Diameter (B)
Bolt Hole
Circle (C)
Magnet
Diameter (D)
Mounting
Depth (E) 8.0 in. / 200 mm 8.54 in. / 217 mm 7.09 in. / 180 mm 7.85 in. / 199 mm 4.54 in. / 115 mm 3.85 in. / 98 mm 12864.jpg
Apr 06, 2009 | OEM Systems Car Audio & Video
MA Audio MA1800XL
Optimum Vented Box: 4.5 Cu/Ft
Round Port Diameter: (3) 4"
Square Port Area: 37 Sq/In
Port Length: 17"
Optimum Sealed Box: 1.75 - 2.5 Cu/Ft these are your options as you can see if your short on space your sub will love a 1.75 to 2.5 sealed box but if you have THE right ported box you will get better bass with less power but at the end of the day that sub will Pump wish i had one good luck hope this helps you info from manufacture cheers bronson
Mar 06, 2008 | MA Audio 800XL Car Subwoofer
Washing Machines Logo
Top Washing Machines Experts
