Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Water sits in bottom
Dishwasher goes through cycle and water doesnt drain
  • Frigidaire Master
  • 3,247 Answers
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Posted on Jan 04, 2013
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
SOURCE: dishwasher not draining
I had water at the bottom of my 4 year old plus dishwasher and of course I thought the worst. Did the pump go out, bad impeller, or what else could it be! I started with the easy stuff first and disconnected the drain lines. The drain line runs from the dishwasher to an air gap mounted to my sink, which keeps the drain line from getting an airlock. From the air gap device another larger line runs to the garbage disposal. I used an 8MM wrench to loosen the clamps enough to pull the drain lines off and drained them into a bucket. There really wasn't any resistance to water flow and no real chunks, I was disappointed.
I then took the actual air gap out of the sink by removing a large plastic nut and pulling the devise out from underneath the sink. When I inspected the air gap I saw a wad of hairy, feathery plastic stuff blocking the flow of water. I took the chunk out, reassembled everything and it works like new again.
It is a very easy fix and now even the area under the sink is clean to boot.
Jerry
Posted on Oct 18, 2008
  • 10865 Answers
SOURCE: dishwasher will not drain the water
Chances are that something is plugging up your little waste water pump. Easy fix. Just open up the bottom panel on the lower front of the machine. You will see the drain hose with a little pump attached at one end and the other end heading out of the space and into your sink space. Just disconnect the hose and then unscrew the little pump. you are looking to remove a piece of glass, or bone or some other obstruction and remove it.
Posted on Mar 10, 2009
  • 864 Answers
SOURCE: Water will not drain out of bottom of
Check the input to the drain hose to make sure it is not blocked by something like a cherry pit.  That could cause the water to not drain fully.
Posted on May 20, 2009
  • 10865 Answers
SOURCE: there is water in the bottom of the dishwasher
Hello. Most likely you have a partial blockage in your dishwasher drain line between the floor of the machine where the drain pump may have debris in it and the trap under the kitchen sink. If you are handy you can remove the lower front panel of the machine, locate the small pump at the end of the drain hose, remove the pump to physically examine it and remove any glass or other debris in there and then check the rest of the drain line right to the trap under the sink.
Be sure to begin by turning off the breaker to the dishwasher to eliminate any shock hazard. J.
Posted on Jun 03, 2010
Have a Samsung dishwasher DMS300TS displaying E3 error. Manual says blocked drain but all is clear and impeller moves freely. Any clues?
Do you have a drain vent that goes up to your Counter/Sink next to your faucet? It's a called an Air Gap or dish washer drain vent. Sometimes those get clogged.
Also, make sure your drain hose does not get pinched when you move the dishwasher back into place. Hope that helps
Good luck
Mar 11, 2018 | Dishwashers
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
I have a 501 ht moyer diebel undercounter dish washer that doesnt drain all the way
Could be a clogged drain line, a failing pump or even the dishwasher not level
Jan 16, 2013 | Dishwashers
I have an E39927 Type 776-0 dishwasher. The problem began this week, in that water does not fully drain from the dishwashwer following the end of any of the washing cycles. The unit seems to be...
disconnect the drain hose from under the sink. place it into a bucket and put the dishwasher to drain. if it drains in the bucket fine then you know you have a problem with your drain. if it doesnt drain, then the problem is most likely the drain pump
Oct 23, 2011 | Maytag Dishwasher
Water doesnt drain and water nozzle doesnt spin...but it cycles
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Hotpoint 24 in. HDA3400G Built-in...
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
Water will not drain .cycle stops , will not start even on new cycle
The water will have to be evacuated first. there may be a blockage either in the outlet of the dishwasher or the drain connection under the sink. The dishwasher tries to drain at the very start of the cycle. If this doesnt happen then a new cycle wont start.
Jul 31, 2010 | Dishwashers
Water Remains in dishwasher after cycle
Few things to check....if it is a push button....press the start button and then press the cancel button, the drain should engage. if it is a timer setup, turn it to the cycle start and close the door, will drain unit. If water doesnt drain and you hear a pump running then you have a clog.....be sure to check your disposal plug,where the drain hose connects to. if water just appears in d/w while not in use check the drain hose position....should loop up from the drain to prevent backwash into d/w.
Jun 10, 2009 | Dishwashers
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
120 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
