Question about NPR Music
NPR Music streams for about a minute then stops
Stream is fine for one to three minutes then just stops. This started 12/27 - prior to that I could listen to the stream uninterrupted for hours
  • Larry Wheelock Jan 03, 2013
    More info -- this is happening on my iPhone 4 and on my iPhone 5, both running 6.0.1
    Even more info -- I deleted the app on both phones and re-downloaded it from the app-store. Same problem.
Trailblazer slow excelleration from 1000 - 3000 rpm.
several things on a 4,2 can cause lazy acceleration,but the most common is a plugged catalytic converter,check up stream and down stream o2 sensor for activity,up stream should be swinging low and high and downstream should be fairly steady if cat is good,if down stream is erratic like up stream reading low to high 7 to 10 or more times a minute,suspect faulty cat. you can buy after market cats cut out the old one and weld in new one,much cheaper.
Nov 03, 2016 | Chevrolet TrailBlazer Cars & Trucks
How do i stop sound bar from turning off
hmm i would check the settings with it with your remote.
Nov 15, 2014 | Polk Audio Surroundbar 3000IHT Home...
Index sand filter pump SF 20110 will not blow water into pool
I don't know how much time you are giving it, but sometimes when I start my pump, it'll take 20 minutes or so for it to start a full stream of water. Also, make sure the valves are turned to the unlock position on the incoming and outgoing hoses.
Jun 03, 2014 | INTEX Sand Filter Pump
I have a Roku 3 which uses the Internet to access Netflix. My ISP gives me unlimited access during 23.00 and 07.00. Is it possible to down load a film during these hours and view it a few hours later
Netflix will only load the stream for a short time before it stops, streaming must be done live but you could pause it but doing so all night would not be of much help. Just start and hit pause 10 to 20 minutes before you really want to watch a film or show. If this is really a problem you may need to improve your internet capability either through increasing speeds, getting a plan with less throttling, or moving the router closer to or connecting directly to your devices. Other than that you could download movies and avoid the problems of streaming altogether.
Nov 21, 2013 | Roku 3 Streaming Media Player - 4200R
Why do the stream fail after one minute in to a movie and keeps it up every minute
Go to speedtest.net and run a test to see if your download speed is really okay. Then run command prompt and do a ping test to the movie site and see if the transit time is within acceptable range.
Feb 15, 2013 | Computers & Internet
Other computers not able to connect wireless
have you downloaded any new software/games/audio/video in the last two weeks on the main pc w/router (that might be conflicting)..if so I would delete it....do not change wii or other computers connection settings....but on the main computer lets do this
1.go to start
2.all programs
3.accessories
4.system tools
5.system restore
6.we are going restore 1 full month...this means pick restore to earlier date....30 days back.......when it was working all fine.....click okay..once say ok again it will reboot by itself come on and will prompt you one more time click ok
good luck
May 21, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
FLASH VIDEO PLAYER STOPS AND STARTS WON'T RUN CONTINUOUSLY
Increase the buffer size. Your PC is playing the video faster than your internet connection can stream it to you. Let the PC load the video for a minute or 2 before you start viewing it. (Not all websites load video until you begin playing it, so this may not work)
Oct 07, 2009 | Microsoft Windows Vista Home Premium...
Can Not Stream Music on S 9
does your phone have a2dp bluetooth profile you need that for music to be played
Sep 06, 2009 | Motorola Mobility S9 Headphones
Logitech Web cam freezes every few minutes when used with Skype
Look in device manager See if there is a memory conflict with another device
Jul 27, 2009 | Logitech QuickCam Connect Webcam
Power Brightness dims after using Kinoma Player
Ok i think i can help,
Step 1: Go to preferences
Step 2: Go to power
Step 3: Change the Auto-off after: feature and increase it to 3 minutes, the maximum.
I know this will only help it a lil from the 1 minute you had before, but if you pres the volume button or something within the 3 minutes it will restart the 3 minutes.
Masalama
Sheeraz Khan
Jan 02, 2008 | Palm Treo 755p Smartphone
NPR Music Logo
69 people viewed this question
Top NPR Apps Experts
Erin Wood
Erin Wood
Are you a NPR App Expert? Answer questions, earn points and help others
