Question about Lexmark Optra T610 Laser Printer
Error 241 lexmark optra t610
241 paper jam check tray 1. There is no apparent jam
3 Suggested Answers
antiochpc
  • 1314 Answers
SOURCE: optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Posted on Nov 10, 2008
mariolands
  • 2296 Answers
SOURCE: OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Posted on Mar 07, 2011
I have a paper jam. Is there a paper feeder button or anything I can do to get the paper out. I have already taken out the paper tray, toner cartridge and opened the back and can barely see the paper. I...
To access possible paper jams areas, please click the link http://bit.ly/jtehCY and then go to page 69.
The manual shows the path the paper travels through the printer and the options. The path varies depending on the paper source and paper exit selection (output bin). The jam areas are also shown on the pages.
For further assistance, please contact Lexmark Technical Support.
Jun 30, 2011 | Lexmark Optra T610 Laser Printer
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
Get the error message change tray to plain letter
Most probably the paper tray guide is not set properly. Here's a link to the Lexmark website to guide you on what to do when having an error like this. Just click on this link: http://bit.ly/c4AO17 . You can move the paper tray guide back and forth and setting it to the correct size.
Apr 08, 2010 | Lexmark Optra T610 Laser Printer
I have a optras1855 printer and a message keeps coming up 241 paper jam check tray 1. the problem is there is no paper jam. i know this because i have another machine the same model and that does the same...
I'll bet that if you put a mark on the top sheet of paper in tray one and then send a print job or run a self test you will see that the paper stays in tray one. I suspect that you have a paper pick problem.
Worn or slick rollers can be one source or a weak tray supports. Also, take the paper out of tray one and fan the paper to break any static that may cause the paper to stick together.
Don
Dec 17, 2009 | Lexmark Optra S 1855 Laser Printer
Stopping the lexmark optra t610 from resetting
sounds to me like a dead back up battery. I think you'll have to call a dealer to confirm this, and they would have to replace it for you
Mar 14, 2009 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 keeps saying "change tray one to plain paper"
3 possibilities
1) the paper size sensor in the tray(those teeth on the size of the tray) is broken
2) The sliding paper guide is not pointing precisely at Letter
3) Your paper type is set to something other than Plain Paper.
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Our lexmark Optra T610 laser printer keeps telling me to "change tray one to plain paper"
verify paper tray is set for correct paper. print the configuration menu and check the paper size for tray 1. If it does not have right size, examine the tray bottom to see if slider is in place
Optra 2450 error 241
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
Printing envelopes
you can replace the paper in the main tray with the envelopes. this is the only way unless you have a secondary paper tray or manual paper feed that does not override the main paper feed
Oct 03, 2008 | Lexmark Optra T610 Laser Printer
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 Laser Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
