Question about Raypak Pool & Spa
Hi i have a Raypak Spa Heater model 160PH AL97030438 and it keeps blowing fuses every time. I can light up the pilot light and turn to the on position. but when i turn on the power to the unit it blows the fuse.
    Top Expert:
  • Raypak Master
  • 4,292 Answers
Something is shorted
Posted on Apr 27, 2016
4 Suggested Answers
  • 4 Answers
SOURCE: Fuses keep blowing
probably to much voltage going through i would see the maannual to see if there is any way to lower the power going through
Or your using a fuse which is to low and need to use a higher voltage fuse
if non of those i would call a technician
Posted on Apr 20, 2009
john224
  • 1378 Answers
SOURCE: the thermal fuse in my Raypak 105B pool heater keeps blowing.
The thermal fuse react to rollout flames from the burner. Whatever caused your first one to fail caused the second and will continue to be a problem until fixed.
You could have a clogged up heat exchanger from soot and/or debris. You can also have problems with clogged burner tubes.
Finally, you could simply have wind issues that would require a high wind stack being installed on the heater to correct.
Posted on Jul 26, 2009
  • 990 Answers
SOURCE: Raypak minivolt pool heater ran out of gas was
Make sure you bleed out your gas line and clean the electrical ternimals on the wires. Other than that it will be a weak pilot and will need a new assembly or a bad gas valve and will need a new one. These can be checked with a milivolt meter as they are expensive to go part changing to repair.
Posted on Jun 27, 2010
Can dirt prevent the pilot to light on?
yes if inside gas line to pilot or cobwebs blow it out
May 12, 2014 | Raypak 2100 Pool Heater Gas 266000 BTU'...
Raypak pool heater pilot light problems
Could be several things. The heater should still be under warrantee. Have RayPak send a tech over, any DIY will void the warrantee.
Aug 02, 2013 | Pool & Spa
Pilot won't light
if gas check for cobwebs if ok replace pilot generator
Feb 15, 2013 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Pilot lights but burner won't light. Display continues to read SPK
On these units, the pilot ignitor and the pilot rectefier are the same part. The pilot can be lit, but not be sensed by the rectefier/ignitor. This will keep your burner tray from igniting. You need to replace the ignitor assembley. If it is the same as the raypak digital 406a I charge about $75 for that part, and it takes about 20 minutes to install. Need the part or more help e-mail me. adamh@newconceptchem.com
Oct 22, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater - error code is "FAN"
In models older than 07-07 it typically indicates a loss of the pilot light.
In models newer than 07-07 it is probably the air switch not being activated, or it has just failed. Check air switch tubing for secure connections.
Oct 03, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Pool Heater
check to see if ignitor is lighting if so check gas line to ignitor if no ignitor replace and check safety circuit
Nov 05, 2008 | Raypak DOOR ASSEMBLY
Pool & Spa Logo
60 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
