Question about Dryers
Drum off center
Fridgidaire fdg436res2
  • Dryers Master
  • 8,220 Answers
Thats a busted center bearing most likely as shown in this home video of mine:
How to replace it and more here:
Posted on Jan 04, 2013
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
Installation Tips: Ribs face toward drum
For 1985-1995
For 1995- present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
For Ge Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
on Mar 02, 2010 | Dryers
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
For Amana all models will look like this
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Fridgidaire model gler331as2 drum wont turn with full load
The belt may be worn and slipping or the belt tension idler may be failing or broken
Sep 10, 2012 | Frigidaire GLER642A Electric Dryer
Model 708 has a high speed bearing noise during rinse cycle Can bearings be replaced?
Hello,Here is how to tell if it is the rear bearing. Open the door, grab the inner drum and see if you can move it while not moving the outer tub. If you can, then the rear bearing is bad. Fridgidaire doesn't sell the rear bearing by itself, they sell the rear outer tub shell, also when this happens the shaft on the inner drum is worn and has to be replaced. I have seen this repair cost as much as 600 dollars USF to do this repair. What causes this is using too much or high sudsing detergent. The rear seal is a water seal, however suds will wick pass the seal like a light grade oil. Also water will not remove the grease from the rear bearings, however detergent is designed to do just that. You may try calling Fridgidaire and see if they will at least provide the parts at No Charge.
Thanks
May 22, 2010 | Fisher and Paykel Fisher & Paykel Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire GLET1041AS1
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
Sep 30, 2008 | Frigidaire GLET1031 Top Load Stacked...
Fridgidaire gallery
From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
Feb 08, 2008 | Washing Machines
Dryers Logo
Top Dryers Experts
