Question about Brother IntelliFax-4100e Fax
Not printing, but says it is
I have a Brother IntelliFAX 4100e and it says on LCD "printing, online", however it doesn't print anything and won't send anything out. I have tried unplugging it and after I did that and plugged it back in, one fax came through. However, nothing else is coming through. Any suggestions? Thanks.
  • STEVE RAYMOND May 11, 2010
    give me more info so i can help you
I have a fax machine with the sam problem, what i did to resolve the issue was removed the 3 screws and removed the back cover, disconected the battery then removed the cover over the parallel port. I then disconected the 5 connectors on the right towards the rear of the printer 4 white 1 red, reconnected the printer to power with the connectors disconnected, then after 30 seconds i unplugged the printer reconnected the cables and it worked, has failed since
Posted on Mar 15, 2009
  • hectorhenry Mar 15, 2009
    correction, HAS NOT failed since
I tried the solution above, posted by HectorHenry, and it seems to have worked like a charm. Thank you!
Just to recap:
Unplug the fax machine.
Remove the back panel from the 4100e which covers the parallel port. This consists of 3 philips screws.
You should see a battery pack sitting right there with a little connector on it, just unplug that.
Then remove the metal casing which is covering the parallel port and circuit board - this is about 8 screws, also philips head, but a bit smaller. There are really two pieces of sheet metal that comprise the cover, feel free to slide both of them out.
Towards the right of the board, near the end where you're working, you'll see white connectors of various sizes - four of them. You'll also see one red connector. All the cables were white in my case, so pay attention to the connector color. Disconnect all five of these connectors.
Plug the power cord back into the fax for about 30 seconds. After that, unplug it again.
Reconnect all your connectors and the battery. Plug the fax machine in and test it. It should be working.
If so, just screw everything back together. If not, try one more time and leave everything disconnected for a few minutes.
If for some reason this does not fix the problem I suspect you have a different problem altogether... In reality I think you may only need to unplug the battery pack, but I tried all the steps above just to be certain.
John
Posted on Mar 25, 2009
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
My Intellifax 4100e has 22 faxes in memory. How do I print these ones in memory and then clear the memory?
Hi Veronica, try this: press "menu" then "254" then "fax start". This should print out what is in memory.
Sep 04, 2013 | Brother IntelliFax-4100e Fax
2" black band prints on right-side of every page
print a report, any report, from your control panel. if it looks good and your band is only on copies and transmitted faxes, that would be your Contact Image Sensor going bad. its located under your document feeder and looks like a sinny piece of glass that runs left to right.
hth,
razors
Nov 14, 2011 | Brother IntelliFax-4100e Fax
Has 70% memory, but will not print. Says printing online, but not printing
Press "Menu" & "Mode" keys. Display should clear. Then press 0, enter 91. Hit stop after completion.
Nov 03, 2010 | Brother IntelliFax-4100e Fax
Fax machine says: Printing Online on its LCD readout but won't print anything. We have replaced the drum and the toner. We can't get the message to clear either
Press "Menu" & "Mode" keys. Display should clear. Then press 0, enter 91. Hit stop after completion. THIS WILL CLEAR ANYTHING IN MEMORY.
Aug 17, 2010 | Brother IntelliFax-4100e Fax
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
Intellifax 4100e is not printing faxes says printing online? Or it stops in the middle of a fax and says same.
try parameter reset function (this will change some settings back to default)
hit these keys all within 2 seconds!!!
function (or menu) * 2 8 6 4
should say maint.mode: then hit
"9 1 set" and then "9 9 set" That will usually clear out any brainfarts in the system. This also works for code 77 errors (9 9 set is the actual parameter reset)
Oct 13, 2009 | Brother IntelliFax-4100e Fax
Printing all document out the back of machine
There is a lever in the back, lift it will divert the papers to the front again. ( looks like a small door)
Dec 09, 2008 | Brother IntelliFax-4100e Fax
Error 11...what does it mean?
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usually just after warranty has expired!
Jul 14, 2008 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Logo
554 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
