Question about Samsung SCX-4216F All-In-One Laser Printer
I have problems printing output from samsung scx4216f...
When paper tries to exit the printer it starts to grip tightly and rip (centre of paper over a widthe of 6 cm's) and then jams up even when printing just 1 or 2 sheets.
I clear it and cannot see any impediment either via the back of the printer or by taking out hte toner or papaer tray - even swopped toners but no difference.
Have had problem over a year ago when doing very large print run and assumed this was due to the heat buildup. I would find a spec of paper stuck to the rollers on paper exit route at back of printer, clear it ,let it col and al would be ok!
But I can't do anything this ytime as nothing seems to be stuck - looked and examined thoroughly!
Do I need to take it apart? - If so what do Ineed to do?
Look forward to your help!
Regards, Gwyn
    Problem Solver:
  • 10 Answers
Gwyn, from my experience is the type of paper used. Get the one that is 150 grams. Thicker. It varies on the manufacturer. The regular one is 75 grams.
The printer is just like that.
Posted on Apr 25, 2010
How to output bin empty ?
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
Jan 20, 2015 | HP LaserJet 5200 Printer
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Printed paper is stalling within the output.
That's a common problem on that machine, those rollers at the exit get coated with toner and fuser oil, so they have no grip to pull the paper thru. If you dampen a rag with alcohol and power off the printer, each time you turn it on or close the front door the rollers turn and you hold the damp rag against the exit rollers one at a time to clean them...
Nov 13, 2009 | Brother HL 1250 Laser Printer
Paper jam at exit
The rollers at the exit area are worn out. They can be changed, in the mean time you can use something like sand paper to rub across the rollers to take the smoothness out of them. That will help them get a grip on the paper as it is exiting.
Jun 02, 2009 | Samsung CLP 300 Laser Printer
Paper jams after printing and will not exit top output tray
take it back -- Samsung has a year warranty, but if it's brand new, take it back. I've had two 2510's and have been happy until they get some wear on them, then I have the same problem. This ought not to be happening to a new machine.
May 30, 2009 | Samsung ML-2510 Laser Printer
sounds like the gear drive assy faulty.take it back to where you purchased.Samsung should cover under warranty.
May 25, 2009 | Samsung ML-2510 Laser Printer
Printer jam upon exit
Check the paper output area ( around the output rollers) for a small piece of paper. You may need to disassemble the output paper assembly, and clean the rollers, or replace the paper output assembly.
In reality, what you have is one part of the printer trying to "push" the paper, while another part of the printer is trying to "pull", resulting in the wrinkle.. The problem may also be with a paper output sensor being stuck, which is why I suggest you check thoroughly for paper scraps in the output assembly.
Nov 14, 2008 | HP LaserJet 3030 All-In-One Printer
Paper output slot
there is still a piece somewhere,
1-where you put the paper there should be a lever,this tells the machine paper is present to print.
2-At the exit there is another lever telling it paper is going out and if there is a paper there.
Check to make sure these levers are free and can move easily, one may be stuck. Maybe you ripped the paper when trying to remove and a piece was left behind.
Jul 22, 2008 | Canon BJC 5100 InkJet Printer
Samsung CLP 550N paper jams
Make sure the paper guides are not too tight and always fan the paper to rid static build-up before loading.
Jan 19, 2006 | Samsung CLP-550N Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
49 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
