Question about Refrigerators
I have a GE fridge Model PFS22SISBSS. The motherboard has been replaced once already. The freezer temp started fluctuating from -1 to 18. GE recommended replacing the motherboard again. I bought one (PN WR55X10942) and the instructions said to cut Pin 2 of J1 (Thermistor Wire). I did and put the new motherboard in. Not the freezer display indicates -47 all of the time. Does anyone know if the instructions are incorrect and if I shouldn't have cut that wire. BTW...GE said they won't replace this board because I am an end-customer and that I voided the board warranty by putting it in the refrigerator. My kid could have put the board in ...it's not rocket science. EXTREMELY FRUSTRATED WITH GE.
3 Suggested Answers
SOURCE: GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Posted on Jan 18, 2010
kvhappliance
  • 218 Answers
SOURCE: brought the GE WR55X10942 Refrigerator
Yes you will need to cut the wire the directions states all bottom freezer models and models with certain serial numbers... But you will not need to do other modifications specifically for bottom freezer only models.
Posted on Jul 15, 2011
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
ICE MAKER NOT WORKING ON GE PFS22SISBSS
Lets try this first. Unplug and then wait 10 minutes and then replug. That should reset the memory for the motherboard. If that does not work contact me asap, Sea Breeze
Mar 13, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
I now have same problem as arjaybeee posted on Oct 29, 2009 PFS22SISBSS digital temp. control LEDs not lit, so can't see the settings for fridge or freezer spaces. The spaces are being cooled, though, but...
It may be as simple as a blown lamp bulb.
Check item #624 on the diagram at this link. You can also order your part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218255&diagram_id=26230025#d26230025
Jan 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
GE PFS22MISBWW is a piece of junk
One doesnt like to hear it but possibly cut your losses and look for a less complicated fridge with minimum electronics.
Jul 21, 2009 | GE PDS22LBN Bottom Freezer French Door...
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
