Question about Schwinn Original Airdyne
*O I am trying to remove the wedge pin from the left eccentric crank on my Schwinn Airdyne. The nut on the top of the wedge pin is loose and turns freely but will not come of. It just spins freely but
The nut is loose enough so I can turn it with my hand, but it does not seem to be engaging the threads at all. I keep turning it and it never makes any progress moving up the threads to come off.
goalie39
  • 469 Answers
SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Posted on Apr 19, 2009
terpcafe
  • 16 Answers
SOURCE: Looking for a Manual for an OLDER Schwinn Airdyne,
Send me your email address & I will send you a copy of the airdyne manual I scanned. It is a pdf copy which has description and instructions for your Airdyne computer. It has automatic (scans all features) and manual (stays on the 2 items you select in the display windows)and tells you how to change from manual to automatic and how to operate the computer. (terpcafe@yahoo.com)
Posted on Sep 27, 2010
terpcafe
  • 16 Answers
SOURCE: I bougt a used schwinn
Your computer's pickup magnet pickup sensor is not reading the magnet as you spin the bike. You probably have too much of a gap in between the magnet sensor and the magnet on your bike. Gently push the metal bracket holding your magnet sensora bit to close the gap and it should then read your magnet, calculate RPMs etc. Terpcafe@yahoo.com
Posted on Oct 24, 2010
  • 1788 Answers
SOURCE: I have an older schwinn airdyne with the
I would take it in for service and let the professionals give it a tune up. You have a very good machine and I am sure that it needs to have the bottom bracket tightened and lubed. We have sold over 5000 Schwinn Air Dynes since 1981 and they are always worth fixing. So give it some love and it will be with you forever. Doctors and sports teams love these machines because it has a measured workload and they can write a program for you. We sell lots of excercise machines, treadmills etc but the Schwinn Air Dyne is the best of all of them.
Posted on Dec 30, 2010
terpcafe
  • 16 Answers
SOURCE: My Father has a schwinn Airdyne. the pedal was
There is a metal shim needed in the bike/pedal that has to be tapped in to keep the pedal tight. If you dad has used the bike for several hundred miles and/or his feet might actually bend the pedals over time (weight), it is possible the metal piece that the pedal attaches to could become bent slightly, and I have seen a few bikes, that need to be taken to the bike repair store (call a large bicycle/itness store) that has a good repair shop and they often can repair these, but rarely less than $125 for an Airdyne repair/tuneup.
Posted on Jun 06, 2011
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Replacement batteries for Schwinn Airdyne AD3?
It should just be 2 AA batteries. Remove the battery door on the back of the computer to expose the batteries. Remove and replace. Computer Graphite Airdyne Big Fan Schwinn 92823 SPORTSMITH net
May 16, 2014 | Schwinn 430 Elliptical Trainer
99 sable crank pully nut
It's a bolt, and if left hand threads, it will be the first time I have heard of such. No pin would be through the threads. Try the breaker bar or impact gun the other way. If engine tries to turn, pull the starter and wedge a block of wood against the ring gear teeth on the flywheel.
Don't know about sables, but thought all crank bolts were regular threads.
Dec 28, 2012 | Cars & Trucks
How to attach book rack to 1984 Schwinn Airdyne
Remove the computer support brackets by unscrewing the bolts holding it to the bike frame. Get 3-4 inch long bolts (to replace the computer support bracket bolts) and nuts that will tighten on the other end and place the book rack support brackets in front of the large inverted U part of the bike frame. Align the holes of the book rack support with the computer support leg holes. Insert and tighten the new longer bolts with the computer legs on one side of the U and the book support legs on the other side of the U. Once you tightne the nuts, your airdyne now has both the computer and book rack on it.
May 29, 2011 | Schwinn Original Airdyne
My Father has a schwinn Airdyne. the pedal was loose, I bought a new piece that fits through the pedal, replaced it but it is still loose. I think the medal in the crank wheel is worn...... Because the...
Feb 18, 2011 | Schwinn Original Airdyne
The handle bar got very loose while i was using it it suddenly went to the left this is a staionary bike the schwin areodyne can i fix this? i cannot afford repairs seems there is a big lug nut holdind...
http://www.fitnessrepairparts.com/diagram/113 This is an on-line link to the schematics for your Airdyne. The large nut between the handlebar (foot part) and the wheel hub are supposed to be pretty snug. Tighten the nut using a 6 or 8 adjustable wrench and tighten the nut clockwise. Be careful not to tighten too hard or the handlebar will not move at all. This is a very easy fix.
Jul 11, 2010 | Schwinn Original Airdyne
Error code 1 on schwinn elliptical 418 how do I fix it. I have replace batteries and unplugged unit. Error 1 shows up as soon as I turn unit on.
E1 error seems to indicate that the servo which controls the elliptical resistance is stuck. Here is how I fixed this (without using a "crank puller", which would be quicker by far).
You will need a very short phillips screw driver (snub nose), a long phillips screw driver, an allen key set, and crescent wrench.
- Remove the batteries from the unit.
- Remove the screws from the plastic housing (with the long phillips screw driver) on the left side. Do not forget the phillips screws at the front - they are smaller screws so don't mix them with the others. This will allow the plastic housing to flex and move around, but not come entirely off.
- Using the crescent wrench, remove the nut holding the left pedal to the crank. Carefully note the order of the washers on the crank attachment.
- Using the allen key, remove the little pedal attachment piece on the left crank arm.
- Using the short phillips screw driver, carefully reach inside the plastic housing on the top and remove the four screws holding the plastic plate on the outside of the fly wheel/crank. You will need to rotate the crank wheel to reach each of the four screws in turn on the inside of the case.
- Pull off the plastic cover for the wheel.
- Reinsert batteries and gently help the revealed cable (bottom) retract the magnet plate. In my case, the servo worked fine again after helping it retract the magnet plate that was somehow stuck/wedged.
Reverse steps to re-assemble.
Jan 16, 2010 | Schwinn 430 Elliptical Trainer
Schwinn Original  Airdyne Logo
87 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
