Question about Philips 42PFL5603D 42 in. LCD HDTV
Philips 42PFL5603D keeps switching itself on and off
Turned our tv on this morning and it had a black/grey cloud in the middle of the screen. We've tried turning the brightness up and down to see if that will help but it hasn't made a difference. All the tubes are still fully lit so I don't think it is that. It's now switching itself on and off. Anyone else had this problem and if so if there a solution??? Many Thanks
  • 52 Answers
SOURCE: 42" Philips plasma screen goes black
you need to replace y-sustain board.
Posted on Jul 25, 2008
SOURCE: Philips flat screen TV MODEL ID 19PFL5422D/27
I bought the television less than a year ago, so I called Philips Magnavox and they asked for the serial and model numbers. Next thing I know they asked for my name and address and Philips is sending a brand new television to replace it !!! The new one should arrive in about ten days. How's that for service? I'm very happy that I bought Philips and I will do so again. So don't forget to keep all the paper work that comes with your new televisions,especially Model and Serial numbers ! Thanks for asking , Debbie Hoffman
Posted on Aug 19, 2008
SOURCE: Philips 30PF9946 D/37
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
Veritas
Posted on Dec 09, 2008
Highdefjeff
  • 124 Answers
SOURCE: need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Posted on Mar 03, 2009
maatmartin7
  • 1213 Answers
SOURCE: Looking for replacement panel for Philips 42'' model #42pfl5603d
Visit Anrews Elctronics.com. Ask for a salvage part.
Posted on Dec 25, 2009
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
Philips 42pfl5603d/7 turns off and on by itself then turns blue in a matter of a few minutes of being turned on.
The main power regulator board should be checked for any loose solder terminals. Re-solder all the suspected solder terminals there. If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 17, 2013 | Philips 42PFL5603D - 42 IN. LCD HDTV
When i turn on my tv it stays on the philips screen. never goes to tv. i tried unplugging it and leaving it unplugged for an hour, no help
You give insufficient information to provide you with a more streamlined solution, so excluse me for being too brief.
What I'd do if I were you is to try and re-flash (update) the firmware in your TV.
if that doesn't help you'll likely need a new main board.
TO update the firmware you'd need the exact model of your Philips. 42PFL5603D has two versions - /F7 and /27.
The update for the first is at
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL5603D/F7&slg=en&scy=US&mid=Link_Software
The second is at
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL5603D/27&slg=en&scy=US&mid=Link_Software
Those are Philips provided and supported pages, so you should be able to find your way around there.
Hope this helps. If it does, please rate it with thumbs up - we need your votes if we can't get your money :-)
www.coppelltvrepair.com
Oct 18, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
Screen frozen
I've had this same problem and we only bought this TV back in July. It seems to be getting worse. Anyone have any answers?
Feb 07, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
Lcd tv shuts off by itself and then turns on by itself
philips tv turns itself off and on agianevery 10 mins roughly with a gap of a few mins before coming back on. only had a few months
Dec 27, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
How do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
Nov 18, 2009 | Philips 42PFL5603D/F7 LCD TV
Ive a phililps lcd tv i get red lines all over the screen
Check out this website as it gives you some possible solutions to this problem.
http://ezinearticles.com/?LCD-TV-Problems---How-You-Can-Fix-Them-Fast&id=2032990
Aug 31, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
One half black verticle screen
Manufacturer Philips Part Number 932224850682 Description LCD DISPLAThis part is no longer available
Aug 20, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Philips 42'' flat screen
Bring your TV to eletronics technician. The main power of your TV has a broken semiconductor parts that need to be replace. ( Maybe power mosfet, fuse, transistor, capacitor, etcc ).
Jul 23, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Toshiba TV colours wrong pink sky, blue clouds and green people??
Inside your TV there is like a loop of insulated wirings the loop around the screen. This is to demagnetized the tube. There is a varistor which looks like a thick coin with two leads on it, or sometimes it looks like a flat ceramic capacitor that control this loop of wire. When you first turn on your TV current goes through the loop of wires to demagnetize the TV then the varistor shuts off. Sometimes this varistor fails, causing smeard colors. You can also demagnetize the screen without opening the TV. Using a hand held demagnetizer. It can be purchased at some electronic parts store.
Jun 28, 2009 | Televison & Video
Philips 42PFL5603D 42 in. LCD HDTV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
