Question about Brakes for Ford E350
How hard is it to replace front brake rotors on a 92 Ford E350? Do you need any special tools?
  • Ford Master
  • 14,381 Answers
Hey Dennis,it's simple,here's a guide on how to replace,here are the the brake rotors.
Posted on Jan 04, 2013
1993 ford e350 cutaway
brake fluid hose towards the front wheels in the brake master is blocked.
Jun 20, 2013 | 2002 Ford E350
Brake rotor removal
you shouldn't need any special tool all you have to do is remove the caliper assembly of the rotor and the rotor should come right off. If not then the rotor should come off if a there is a nut holding it on there
May 10, 2013 | 2005 Ford Freestyle
How to replace front brake rotors on ford e350
E350 is a little more difficult because you have the hub bearings in the rotor. You will Nerf to repack these bearings when finished. If your still interested I'll give instructions I'm the morning. Just let me know.
Dec 27, 2012 | Brakes for Ford E350
My Ford E-350 Van Shakes when braking. I have replaced the Rotors and Brake pads and it still shakes only when braking. What else could be causing this?
Welcome to the world of Ford Truck!!! The rear rotors come off the same way that the front rotors come off, only they get REALLY stuck to the rear hub assembly. Once you have removed the caliper and caliper mounting frame, take a BIG hammer and BEAT the rotors loose.
They make a "drum and rotor puller" for this job, but it is pretty expensive - especially if you are only going to do one set of brakes...even most professionals that do these all the time cannot justify the cost of the tool. The rotors for your truck are not that expensive, and they usually get destroyed trying to get them off anyway...so we always replace them at our shop.
Jun 07, 2012 | 2002 Ford E350
1997 ford ranger xlt pickup 4wheel drive need to no how to remove the front roters? some one told me i need a special tool?
it looks like they are still using a floating rotor for 4wh drive
if so by removing brake caliper & mounting bracket the rotor will slide off
spray down around rotor & hab with rust penetrant,couple of taps/hits on rotor face
some rotors have a taped hole(see picture 2 o'clock)using 2 bolts screw in to assist removal
dont see any special tools being needed
good luck
Jun 21, 2011 | Ford Ranger Cars & Trucks
1999 Ford E350 van problem: brake pedal is soft; have replaced master cylinder, rear wheel cylinders, rear brake shoes and drums, front calipers, rotors and discs; have bled master cylinder before...
Good question, on the antilock system is a bleader too and bleade it the same way you bleade the caliper. After all is done adjust the rear brakes, they should have a drag to them.
Feb 23, 2011 | 2007 Ford E-350 Super Duty Length XLT
Front brakes are grabbing
If it is a pulsating feeling (front brake pedal shakes when braking) it needs new rotors.
Sep 28, 2009 | 2002 Ford E350
Replace front brake pads on 2000 expedition
just a toex head tool for the caliper pins
Jan 29, 2009 | 2004 Ford Expedition
97 ford e350 brake pedal goes to the floor...
are your rear drums set up? why did you bleed the brakes. when only when you installed new pads?
Sep 11, 2008 | 2002 Ford E350
Brakes for Ford E350 Logo
49 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
