Question about LG 32LH20 32 in. LCD HDTV
HDCP Locked appeared on my tv screen how can I remove it
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
What does 'this tv dose not support this programs content. Replace HDMI with component cables to view' mean?
The message has appeared because the TV can not display the hdcp signal that is now used to enable copy protection over the HDMI cable due to the TV being older than the hdcp encryption system (the hdcp is not fitted to your TV )
The two options open to you are
Replace the TV with a hdcp compliant TV
Get a component lead set up
Apr 01, 2016 | Sylvania Televison & Video
I have a 2009 Lg 37lh30 Tv and for the most part it works until recently. I am now getting a HDCP rejection when using an Apple tv or Roku and no screen when using my bluRay Player (which use to work
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
Roku 3 hdcp
Hello... I searched the internet and found this. I hope this helps...
To resolve the "HDCP unauthorized. Content disabled" issue, try these steps:
  1. If you are trying to stream 4K Ultra HD content when you see the purple screen, review the instructions for setting up your Roku player for 4K. Go to the next step if you continue to see a purple screen.
  2. On both your Roku player and your TV or AVR, unplug each end of the HDMI cable.
  3. Power off your TV and your Roku player and unplug their respective power supplies.
  4. Reconnect both ends of the HDMI cable, pushing them firmly, all the way in.
  5. Reconnect your TV and your Roku player to their power supplies and power them on.
  6. Try viewing the video again.
If the above did not resolve your issue, try these additional suggestions:
  • Try a different HDMI input on your TV.
  • Try using a different HDMI cable (less than 6 feet if available), just to make sure the cable you are currently using does not have any defects.
  • If you are using an HDMI switch or AVR, try connecting the Roku player directly to the TV.
  • Try another TV, if possible.
  • If you are using a computer monitor, try using a TV, if possible.
  • Try using different Display Settings on your Roku player. You can find these settings under Settings >Display type.
  • If this is the first time you are seeing this HDCP purple screen after setting up your Roku player, ensure that your TV and/or AVR supports HDCP. Contact your equipment manufacturer for more information.
Nov 17, 2017 | Roku 3
Sorry for the duplicate post, but somehow someone's not helpful solution got marked as solved, so I'm going to post again. I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have...
HDCP is causing the trouble You experience. Try using other video input connection for same set. If it works fine that way, the problem is that the rights protection (HDCP) is acting as "police" to prevent copying or reproduce unauthorized content. If only the HDMI is connected (disconnect all other inputs/outputs) on some sets, could be work fine.
Oct 10, 2013 | Sony KP-51WS520 51" Rear Projection...
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Non-HDCP Compliant Error
Jan 06, 2008 | Protron PLTV-32 Television
LG 32LH20 32 in. LCD HDTV Logo
173 people viewed this question
Computer Repairing
Computer Repairing
