Question about Sony Cyber-Shot DSC-S50 Digital Camera
E:61:10 My camera just stopped focusing. I can take pictures but they are blurry and my screen flashes the error code E:61:10. I have tried turning it off and on, taking the battery out, changing the settings, nothing works. I can't find a reset button on the camera anywhere. Does anyone know how to resolve this problem?
  • 1 more comment
  • Redmike Mar 25, 2008
    I have the same inability to focus problem on mine, but I get no error messages. I can take blurry pictures all day. Everything else on the camera works fine.
  • Anonymous Jun 22, 2008
    Same problem error code E:61:10 blurry when you try to take picture; everything else works fine
  • predoehl714 Dec 25, 2008
    Cyber Shot DSC-S50,E:61:10 Erroe, Can I Fit This.
    Genius:
  • 2,985 Answers
Sony Technical Support team is the play to go
Posted on Jun 26, 2007
2 Suggested Answers
SOURCE:
SOURCE: E:61:10
It seems to be a mechanical problem that can be fixed by placing a bit of pressure on key points. Here is the fix that I did that seems to have worked fine...
open the battery cover
take the battery out
take the memory stick out (inside the battery case)
leave the battery cover open
carefully remove the 7 small silver screws (put them in a cup so you don't lose them!!)
slightly pry the front cover away from the camera starting at the bottom
wedge something in the side to 'pop' out the top retaining tabs towards the top
the front cover should now pop off the camra
Make small paper spacer #1:
Cut the adhesive strip off of a post it note.
Fold it over again about 5 times so that it has some thickness to it.
Approx final dimensions are 1/8in x 1/4in x 1/32in(??) thick
Stick it in the upper right corner of the black plastic lense housing.
See photos attached.
(There is a nice flat rectangle at that spot about the same dims.
This spacer should fit neatly right over that space.)
Make small paper spacer #2:
Approx final dimensions are 1/4in x 1/4in x 1/32in(??) thick
Stick it in the bottom left corner of the black plastic lense housing.
(There is a nice flat rectangle at that spot, but you want the spacer
to be a bit bigger so that it covers the vertical line in the plastic.)
Put the front cover back on the camera.
Make sure it is mechanically secure, but don't install the screws yet.
Put in the battery and memory stick.
Try it. You may have to play with the spacer thickness to get it to work.
Once it is working well again, then put the screws permanently back in.
Posted on Aug 26, 2008
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Pictures are out of focus on screen and when taken i cant seem to reajust the focus camera has been working fine untill i went to take a close up shot and now completely blurry .
If you are focusing On a subject make sure first that you are two feet away,
You can also try to turn On the blur reduction under setup menu. make sure also that your on auto mode or smart scene.
when taking picture indoor turn of the flash, you can do this by pressing the flash button On the camera
here are some basic troubleshooting
try to put your camera On a tripod or on the table to stabilize the camera then try to take a picture.
the technique of taking a picture Is first you need to half press first on the shutter button and you will noticed camera will adjust Now if the camera already adjusted pull press on the shutter button.
Blurry picture may caused if camera is not stabilized and may cause also if the flash will not fire correctly.
you may call tech support for further support toll free 1 800 235 6325
Nov 12, 2009 | Kodak EasyShare V550 Digital Camera
Blurry picture nikon s200
It doesn't say lens error? but it won't focus? it is probably the same as the other people who do have lens error displayed on the screen, the lens is broken is what the repair company told me about my s200 when i told me lens error
Jul 22, 2008 | Nikon COOLPIX S200 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
I can turn my camera on then the screen picture is all blurry and it won't do anything if you press the button as if to take the picture. The one thing i have noticed different is the letters [CAF] in the...
When the camera is set to C-AF (Continuous Auto Focus) mode the focus is continually aligned according to movement of subject or the camera even when shutter button is not pressed. The Continuous Auto Focus (C-AF) is disabled while the camera is zooming in and out. Once the camera stops zooming the CAF is initiated and the cameras focus is adjusted.
This is actually used for video.
Jun 06, 2008 | Samsung Cameras
Everything is blurry and out of focus
error code e18 means that the focus motor gears a jammed, dirt or grain of sand in them. you can try to fix it by gently banging the camera on somthing soft, their are also instructions on web on how to disasemble and fix this fault. BUT unless you have some skills, the right tools and conditions i would not attempt it. leave it to the experts
Sep 22, 2007 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
Sony Cyber-Shot DSC-S50 Digital Camera Logo
427 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
