Question about Electronics - Others
My maxell memory stick was working perfectly and then one day my laptop stopped recognising it. All the laptops/computers i have tried it on are doing the same thing. My laptop makes a noise to show t
I have tried it on several computers and each one has recognized it, but it has never shown up or been there to open.
  • 27,725 Answers
A few important bits of information about using faults and fixes on usb drives w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 If you need more help with this post a reply Hope this helps.
Posted on Jan 11, 2013
SOURCE: psp wont recognise my sony 4gb memory stick pro
put a thin sticker on the opposite side of the golden pins and try again
Posted on Nov 28, 2008
  • 7 Answers
SOURCE: computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Posted on Jun 12, 2009
SOURCE: my usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Posted on Jan 28, 2010
laikexpert
  • 281 Answers
SOURCE: I have an 8gb maxell usb memory stick which asks
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 06, 2010
SOURCE: my laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
Posted on May 27, 2010
Windows 7 Cannot find drivers for Maxell 4 GB USB 360
Good day
USB Flash drives use a standard windows driver. This means that the first thing to test is to see if any other USB drives works on your dell laptop. The second thing to test is to use a different USB port. This should eliminate hardware failure. I would recommend simply toing into device manager and look for the universal serial bus controllers. Listed will be all the USB drives. You can simply uninstall all the drives and restart the computer. This will force windows to reinstall the drivers.
Jan 30, 2014 | Maxell 4 GB USB 360 USB 304 - 503201 Hard...
USB only works with some devices
Do you have Windows 8 64bit? Do you have the latest version of iTunes 64bit installed? : http://www.filehippo.com/download_itunes_64/ Is the process started in Services (ipod helper/services process)? This may help: http://www.runscanner.net/lib/ipodservice.exe.html What software do you use for the Camera? Have you tried rebooting the Laptop? You may have to format the Thumb Drive that doesn't work, what is on it?
May 22, 2013 | Toshiba satellite c660
I used this memory stick on my old PC at home and it was wrking okay. When i put it into the usb port it showed up ad removable E. Now I have upgraded my pc to a laptop it doesent recognise the stick....
I assume when you say "memory stick" that you mean a USB memory stick rather than a Sony memory stick.
You should try it in another USB port (if ther is one on your laptop). If that doesn't work, then try it in another PC - if it doesn't work in another PC either, then it is likely that the memory device is at fault, otherwise. If it works fine on another PC, then it is likely that it is the USB port on your new laptop that is at fault in some manner.
If you have another USB device you can use (anything will do - a mouse, webcam, etc), try it in the port you tried the memory stick in. If nothing happens, then in all likeleyhood, the USB port is at fault. If the other device works, then it is probably the USB memory device that is faulty.
If the device works in another PC, try reformatting it as FAT file system on that PC, and see if you can then see it in your new laptop.
Oct 21, 2010 | Office Equipment & Supplies
I have Transcend (JF V30/16GB) memory stick. It is not recognised by my computer. All other memory sticks are recognised. I am unable to use this memory stick. My computer has Windows Vista. Thanks
Welcome to FixYa
Dear User
Check it in another Computer. If your Memory Stick is Working Perfect in the Device which is Using then it Might be password Protected .Remove its Password OR Format it[It can be Possible with in the Device]..
Let me Know if you need further Assistance...hope you got it...
Thanks for Connecting FixYa...
Sep 02, 2010 | Computers & Internet
My usb 4gb flash don my computer only reads in a secure K with 1m
Dec 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My Pc/Laptop (vista) is nolonger recognising my Sony memory stick duo adaptor; I have used it in the past 2 years but for some reason I cant get any of my photos or movies off it!?!?! ahhhhh.... please...
have you tried it on other computer, if not yet try it if it work there, then theres a problem with the port or card reader that you use, if it did not work there then your memory stick has reach it service life
Nov 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
I have a Toshiba Settelite A135-S2386 laptop. When I plag in my memory stick, it says one of the usb attached to this computer is not recognised yet the same stick can be accessed through other computers....
Three things to try -
1 If you have more than 1 usb port try all of them.
2 Switch the laptop off and remove the battery for 30 minutes, replace and try again.
3. Try a different memory stick
Oct 30, 2009 | Toshiba Satellite A135-S2386 Notebook
My computer cant recognize my sps
Before you plug it in,
Make sure the PSP is in USB connect mode.
Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's not this is how you do it:
On the main menu, scroll all the way left to the "Settings" menu. Then select "System Settings." Then scroll to "Format Memory Stick" and press X.
May 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3690-2970 Memory Upgrade
Your laptop may just not recognize and not even boot up if you exceed the memory limit. It will not harm the laptop if you give it a try with the 4gb. However, sometimes caution is a good thing. It all depends on what you are trying to do on your acer. If you haven't already, remove the old memory sticks and replace it with the 1 2gb memory stick. Work with it for a little while (this should not give you a problem). If you feel the laptop is still too slow....let me know...I will look up the compatibility with the memory and your laptop.
Nov 16, 2008 | Acer Aspire 3690-2196 Notebook
Psp wont recognise my sony 4gb memory stick pro
Sep 24, 2008 | Sony 4GB Memory Stick PRO Duo Memory Card
Electronics - Others Logo
50 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
