Question about Dr. Infared heater 1500W Elite Series Infrared Heater with Humidifier and Oscillation Fan
Dr. Heater portable space heater stop working
Just quit working will do nothing
What does a E2 mode mean how do I reset?
The '2' in E2 seems to refer to list of conditions under 'Troubleshooting' in the user manual for this product. The version of the manual that I have found claims that in this condition the problem is: "The amount of heated air exiting the front of the portable heater is reduced."
The solution is to: "Check the electrostatic filter to make sure it is free of dust and dirt. Also check the front grill and rear air intake to make sure it is not being blocked by any kind of debris."by BillBell
below is a few links and the last one is sun heat where you can contact them. press the helpful button,
http://www.qcsupply.com/media/pdf/20451_IOM.pdf
Sunheat SH1500 Space Heater Parts
Welcome to SUNHEAT INTERNATIONAL Family Owned and Operated Since 1954
Feb 02, 2016 | Sunheat SH-1500 Electronic Infrared Zone...
Just bought and plugged in E1 error!! Can't get it to work!!
then return it to place of purchase for replacement or refund .
Oct 11, 2015 | Sunheat TW-1500 Thermal Wave Infrared...
Replace power cord on DR-968 infrared heater.
On most appliances you can swap a cord from any other appliance that you are throwing out. Open up the unit and disconnect the wires (either from crimp style marrettes or crimp push on or crimps with the eyelette) On the housing look for the nylon connector. Pinch this with a pair of pliers and pull out. Putting them back in is tougher but acheivable if you hav patience.
Oct 19, 2013 | Dr. Heater DR-998
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
The water willnot stop running after the heater bloweer shuts off
Typically when the water continues to run after the blower cycle stops, the solenoid valve is stuck open and will need to be replaced.
Nov 25, 2012 | Aprilaire 550 Humidifier
Bionaire space heater Model# BCH9208 blowing cold air
buy an original I- heater at originaliheater.com. they are the bomb with a lifetime warranty
Jan 14, 2012 | Humidifiers
BH 3950 plug overheating
this happens when you have run a heater for a long time on an outlet that is either not giving the heater enough amperage or to much amperage try it in a different room if the problem persists try a different heater.
Nov 05, 2011 | Humidifiers
My forced air central humidification system does not work
you need tocheck for power at solinoid valve or continuity of valve where water enters the unit. THe furnace must be on and humidistat calling...
Mar 12, 2009 | Humidifiers
Dr. Infared heater 1500W Elite Series Infrared Heater with Humidifier and Oscillation Fan Logo
122 people viewed this question
Top Dr. Infared heater Humidifiers Experts
Mack Baxter
Dennis
Are you a Dr. Infared heater Humidifier Expert? Answer questions, earn points and help others
