Question about Electrical Supplies
Wiring up a lighting dimmer switch, 208vac, single pole
  • 3,289 Answers
I'm an electrician and would like to help you. I haven't seen everything - but pretty darned close. With that said..
Where on earth did you find a dimmer switch rated for 208V? I mean, they *may* be available - but I've never seen or heard of one. Can you provide a manufacturer and model number?? With that info, I'll be happy to get the info you need.
Posted on Jan 16, 2013
kcmetal9901
  • 102 Answers
SOURCE: Need help hooking up a single pole Leviton dimmer switch
hook up the red to red
black to black
green to bare wire
tie white wire to other whites in back of switch box in the wall.
If no whites in there cap it off with a wire connector.
Posted on Nov 03, 2008
  • 360 Answers
SOURCE: Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
Posted on Jan 31, 2009
  • 10865 Answers
SOURCE: need to replace the HPM dimmer switch with a normal switch
This is not a difficult job. First of all go out to a home depot or other hardware store and purchase one three way switch. They come in white, cream, and brown.
Back home, kill the power to the lights you are working on. Then open up the dimmer switch, the other switch doesnt need to be changed. Now, simply draw a diagram of where each wire color is now connected and remove the old dimmer. Reconnect the wires. Remember that the white wire goes on the dull color screw and the other two go on the brass screws. Turn the power back on.
If you do all this and the switch only works correctly part of the time just reverse the two wires on the bright brass screws. Please mark this answer as a fixya!
Posted on Mar 09, 2009
frcs68
  • 1605 Answers
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Posted on Mar 30, 2009
loft404
  • 11 Answers
SOURCE: how do I install decora sureslide single pole dimmer switch??
Ok, first turn off power by finding the break box and switching to off. Then I'm assuming you mean by "socket" you mean the hole in electrical box mounted in or on your wall the dimmer is supposed to mount to. Sounds like your electrician ran the power back to the switch through your neutral/white wire. Your dimmer has a top and bottom, it also could possible have a tiny word imprinted that says "to light" and "+" if not attach the white from your socket to the top black wire on the dimmer, then connect bottom black wire to the socket's black wire...ground wires should connect to each other and to the ground in the wall socket. Use wire nuts to secure, then check to make sure no wires are touching anything except for what they are supposed to me touching...and test it before you permanently attach. Go switch power back on, and try your dimmer...if it works GREAT:) Now go turn off power one more time, tape your wire nuttted connections with electrical tape, mount dimmer and go turn back on the power. Hope this helped! Thanks
Posted on Jun 17, 2009
I'm installing a dimmer switch to control two lights. I have three black wires attached to the original light switch that is a single pole. When I hook up the dimmer switch it does not work.
You have either wired it wrong and destroyed the dimmer or just wired it wrong.
I'm guessing that one wire is hot and 2wires go out to the lights.
The hot wire should be on one side of the switch and the other 2wires on the other side.
Here's a video -
Dimmer Switch Installation single pole By Everything Home TV
Sep 17, 2017 | Electrical Supplies
Why after installing a Pass and Seymour lighted single pole toggle switch, the CFLs in my bedroom light flicker on and off.
Is the switch wired wrong?
Does the switch have 4 wires?
Look at wiring for single-pole timer and see it it applies to your switch
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Oct 06, 2014 | Electrical Supplies
Wiring a dimmer switch with 208vac, single pole
208 Volt 2-wire is generally achieved by pulling two hot wires off 3-phase 120/208 Wye or 208 Delta, or Highleg to center tap off high leg delta.
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
http://waterheatertimer.org/images/3-phase-timer-diagram3-T104-208-240.jpg
Since each of these three phase systems also offers 120volt for lights, and a dimmer can be used for lights, then I wonder what you are using dimmer for?
208 volts.can be controlled by turning off one hot of the two hot wires.
Install dimmer on one of the hot wires, and see what happens.
Is the dimmer rated for 208 volts?
Add a comment and say what you discover.
Jan 03, 2013 | Generac HTSN400G 400Amp HTS 3ph 120/208V...
My GE lighted rotary dimmer switch has 3 wires coming from the same hole- 2 black and one red. Is the red wire the ground wire?
No.
It is most likely a three way dimmer, where the two black wires would run to the other three switch, and the red wire would either run to the breaker panel or the light fixture (depending on the electrical box location).
If you're using this in a single-pole application, place a wire nut on one of the black wires, and then wire it as a single-pole device using the red wire and the remaining black wire.
And make sure you have the power turned off before attempting.
Jan 26, 2011 | General Electric Ge Deluxe Lighted Slide...
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
I have the power source in the ceiling. I want to run wire to a single pole switch to a ceiling light?
Disconnect 1 side of light. Wire nut 1 wire from switch to 1 side of wire from light. Wire nut other side from switch to light. You now have a switch inline.
Sep 09, 2010 | Leviton 104-05611-2WS 15A Decora Single...
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
Problem w/new sliding dimmer
The problem is that the Cooper #9530DS-K-L is actually a 3-way switch and you need a single pole dimmer switch to replace your existing single pole toggle switch.
If you want to use the Cooper switch you have you can take one of the black wires and cap it with a wire nut and connect the other two wires, but frankly, you'd be paying about 2 times the price for a 3-way dimmer switch when you only need a single pole switch.
You should be able to return the switch and get the correct one.
You should only have (2) black wires on the proper replacement switch, plus a ground wire
Hope you found this very helpful and best regards!
Aug 07, 2009 | Electrical Supplies
Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
Electrical Supplies Logo
49 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
