Question about GE JVM1640 Microwave Oven
Broken door frame on Spacemaker Microwave oven
The bottom of the outer door frame is cracked and I'd like to either replace this outer frame, or the door in it's entirety. I've seen how to replace the handles (not the problem) so I'm familiar with disassembling the door, however replacing the entire door, off the hinge is what I need help with. Thanks.
MicrowaveSvc
  • 9098 Answers
SOURCE: How to remove the outter door frame on the GE Microwave
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Posted on Nov 06, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: how do you replace a broken handle for a GE Spacemaker II microwave?
On some models, the handle may rotate into and unlocked position then lift out.
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
vitg55
  • 78 Answers
SOURCE: replacement part needed for GE Spacemaker Micro. (JVM1631BB004)
Appliance online store:
http://www.repairclinic.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 01, 2008
Replacing broken door frame; can I remove old glass and hot glue into new frame?
get a tube of RTV compound at Home Depot, Lowes, etc for a caulking gun. Much neater to use as the pros use it also
Oct 09, 2012 | Whirlpool GH7145XF Microwave Oven
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Slight crack in oven door just below the handle. Should door be replaced?
It may be that the handle is getting loose, and cracked the outer door panel.
If so, the outer door panel and handle would need to be replaced.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I would like to replace the microwave oven handle.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1640 Microwave Oven Logo
70 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
