Question about HP PSC 1610 All-In-One InkJet Printer
How do I conncet my hp printer /scaner to efax so that I can fax documents out?
When I try to fax using e-fax I get an error message stating "Could not open the Twain data source" check the Twain driver. What is the Twain Driver?
sandrew
  • 2961 Answers
SOURCE: Scanner will not connect to computer
'Twain' only means 'Technology without an important name', as this is refering to your printer/scanner, i would suggest that you disconnect the printer and remove any driver from Add/Remove programmes. Re-install printer software/driver and re connect printer when prompted and if possible in a different usb port, if that's how it's connected. If the problem persists and the pc is unable to communicate with the printer the fault will lie with the hardware. Hope it's only a driver glitch.
Posted on Nov 27, 2006
SOURCE: HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Posted on Oct 02, 2008
mickspaceNET
  • 115 Answers
SOURCE: Won't Scan
I would suggest you to seek help at a Mac forum.. if it was Windows I could tell you...
I would suggest going to the HP site and look for the software, but for mac. and which mac version?
this is the website.Direct to the.HP PSC 950 All-in-One Printer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategorylc=en&dlc=en&cc=us&product=60259&lang=en
I would uninstall the software and reinstall.. good luck...
Posted on Nov 22, 2008
SOURCE: HP Photosmart D7460 Error Message
Using an administrator account, remove HP Smart Web Printing using Control Panel - Add/Remove Programs.
If required, download and install HP Smart Web Printing from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&softwareitem=dj-56929-4&os=228&product=3551212&
(Thanks to Bellbird at http://forums.pcworld.co.nz/archive/index.php/t-91677.html).
Posted on Feb 15, 2009
How I can receive fax through computer with HP1312?
Hi a barati75
A fax transmission is an analogue communication that was possible on a computer with the old technology of Dial up Modems, which accessed the internet by dialling like a landline telephone. The Broadband Modems (or Modem/Routers) in widespread use today have an 'always on' internet connection and, therefore, no dialling is involved in internet access using them.
You can send a fax by dialling out on the All-in-one printer's telephone number pad. Receiving a fax automatically requires you to have the All-in-one printer's Transmission/Reception Settings set to 'Automatic'.
This fax setup requires the printer's fax cable to plugged directly into an empty Telephone Line Socket on the ADSL filter that plugs into your Telephone Wall Socket and has inputs for your Modem (or Modem/Router) and a Telephone line. If, as is common, your ADSL Filter only has a single Telephone Line Socket and you also require a telephone to be plugged into the same socket as well as the Fax Machine component of your printer, then a Telephone Line Socket Doubler must first be plugged into the Telephone Line Socket of the ADSL Filter which then receives the Fax Line into one socket and the Telephone Line into the other. Please note that every Telephone Socket in the building sharing the same circuit/telephone number must also have an ADSL filter between it and any telephonic device (Telephone/Fax Machine/Answering Machine/Stock Control linked EPOS (Electronic Point of Sale) System/Card Payment Processing Machine, etc.), in order to enable both Computer Internet Data and Telecommunications Data to share the same line without conflict.
Your question asks whether a fax can be received "through" the computer. The above description enables your printer to send and receive faxes 'independently' of the computer while simultaneously providing the computer with printing, scanning and copying functions. For faxes to be sent and received via the computer, software is required. The simplest and most efficient of which is Efax (Electronic Fax (available from www.efax.com) and other similar software available from a variety of suppliers. This software enables the user to send any document or image stored on the computer by fax (without first having to print it) and to receive faxes, at any time, in the form of attachments to e-mails that the software opens, usually as a non-editable PDF or other similar secure Document Format. Faxing a physical document via Efax requires the user to scan the document and save it on the computer first, before sending it.
A combination of a Standalone Fax function setup using ADSL Filters and Socket Doublers + Efax gives the user optimum flexibility in sending and receiving faxes.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment/Clarification Request to this Question.
Thanks for using FixYa
Sep 15, 2011 | HP LaserJet CM1312 All-In-One Printer
Fax problems with hp 5600
I have fax pluged into phone line and every time I try to send it states fax failed. How do I correct
Jan 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Not able to send fax to an eFax number
I've had the same problem before. I don't know if it will solve your problem directly but I can offer a work around or two.
1. I have an efax number but with a company called callwave.com , I fax stuff to other customers using callwave and my MFC 7820n completes each fax successfully. So if you can get yourself a callwave efax number you can fax to yourself and forward fax as an email to your intended party.
2. Or, you can use your mfc 7820n to scan your fax docs as a pdf directly to your computer and then emailing them to your intended party.
Unfortunately it might be a brother issue because at the office when I use the hp fax machine instead of the brother machine, the hp faxes to efax numbers without a problem.
Sep 05, 2008 | Brother MFC-7820N Printer
Communication error
keep the window closed ok? that's more along the lines of the phone issues, than the fax machine itself..there are many ways to outwit the phone tree issues, but each number would need to be encoded directly.
solution?
get a dedicated inexpensive fax machine, or use efax.com
Apr 18, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Compatability with efax
Try Brother customer service 1-800-284-4329 (usa voice #), but be prepared to answer a few questions 1st. The manual mentions nothing about eFax.
Jan 28, 2008 | Brother IntelliFAX 4100 Laser Fax
HP PSC 1610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
