Question about Refrigerators
I have a Samsung RS261 fridge whit a blinking light. None of the button selections are working. What does it mean when it's blinking?
    Genius:
  • Refrigerators Master
  • 1,669 Answers
It is out of synch. Try unplugging the refrigerator or turn off its circuit breaker for 10 minutes or so to see if it resets itself.
Posted on Jan 23, 2013
  • hamed bee
    hamed bee Dec 15, 2013
    this is error sensor-D
2 Suggested Answers
tborn6
  • 700 Answers
SOURCE: i have a samsung RS21DCNS
unitl you either cleanr the code or repair the fault that is what you see.the fault is the ice maker sensor is not reading correctly. check the plug connections for the sensor. if you would like you can contact me and i will help you with this problem.
Posted on Feb 01, 2009
What does blinking temp bar lights mean on RS261 side by side. No response from display
It is telling you the temperature is out of range. Put a thermometer in it and it should be below 40F 4.5C and above 32F 0C.
Nov 13, 2014 | Samsung Refrigerators
How to remove dispenser control panel rs261
I just figured this out. You have to insert a flat blade and pry down and out to release 4 clips along the top of the panel. Work across the top from one side to the other. Eventually it will come loose. After that, 4 Phillips head screws hold the ice and water dispenser in. You may want to remove the freezer hinge cover and disconnect the wide electrical connector before you do this.7cd64856-a478-4204-a8a8-9b0accb8d00a.jpg
Jan 05, 2014 | Samsung RS261MD
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
I have a 6-month old RS261 and when I put in a new filter and pushed "water" for more than three seconds to get the water back on, the red light did not change nor did any water come out. What...
Try holding it for a bit longer. On my fridge, it is hard to push the buttons on the fridge. Sometimes, letting someone else push and hold the button helps. (It's a matter of getting exactly lined up on the contact under the touchpad. So coming back later or letting someone else try has always worked.)
If the above doesn't work, check that the child lock is off. Press and hold the Energy Saver button for 3+ seconds to toggle the lock. If none of the buttons are responding, then the problem may be in the panel. (I refer the problem to a repairman. Membrane type touch panels don't respond well to the cleaning process that I learned for other electrical devices.)
I hope this helps.
Jan 13, 2011 | Samsung Refrigerators
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
I have a samsung RS21DCNS fridge but i have jus had apower cut for 10mins and now the fridge is not working. the lights are coming on inside but there is nothing on the contol panel and none of the buttons...
Jan 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RM255LASH - flashing error code 98 a8 after power glitch
Just happened to me with a power flash- fixed it by pressing and holding the Freezer and Frig buttons together until the screen flashed and reset. Wheww! Though it was a gonner! Fine now:) Hope it works for you!
Nov 06, 2008 | Samsung RM255LASH Side by Side...
Speaker phone light continually blinks
The blinking light on the speaker button means the forward when busy is on. To cancel it- With the handset on-hook dial #12.
Then press your own station number. Then dial # again. The speaker button should stop flickering.
Note: If the SPK button continues to flicker, Forward all is activated. It is the same process as above but use #11 instead of #12
Feb 21, 2008 | Samsung Prostar 816 Phone
Refrigerators Logo
486 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
