Question about Dishwashers
My Brada dishwasher very seldom finishes a cycle but stops and beeps Er. It doesn't matter what cycle it is on either. Also two times when the door is closed and is off it will beep and the china
The dishwasher is a Brada EB6301SS
  • Lorne Olson Jan 05, 2013
    Thankyou for your reply. The warranty on my Brada ran out about 6 months ago. A few minutes after starting the dishwasher on any of the wash cycle selections it will stop and start beeping and flashes Er and the china crystal light will come on and the heated dry light will come on. It takes a while to cancel the Er by pressing the start/cancel button. The same thing happens after staring it again.
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Posted on Mar 14, 2010
Brada dishwasher EF2401 BS, error code E2, will not go to wash cycle it appears and starts beeping. There is no water sitting in the bottom. We have taken out the drain and Cleaned the filter basket
E2 - Abnormally long drain time. Check to make sure that the drain line is not obstructed or bent in a way that restricts water flow. Make sure the drain line is routed below the height of the dishwasher and that it has not been extended. This will inhibit the ability of the drain function to operate properly.
ref. https://support.edgestar.com/hc/en-us/articles/201075515-My-dishwasher-is-displaying-an-error-code-What-does-it-mean-
Dec 17, 2017 | Dishwashers
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Dec 11, 2012 | Fisher and Paykel Dishwashers
Dishwasher not completing cycles
see this causes and fix it. God bless you
If the cycle doesn't complete, check these:Water-heating cycleTimerWater-heating cycleMany dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. TimerTimers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. 9_25_2012_6_48_09_am.jpg
Sep 24, 2012 | Dishwashers
Brada dishwasher ef2401 wont start wash cycle
Mar 13, 2010 | GE 24 in. Profile PDW7800 Built-in...
BRADA dishwasher looking for manuale and instructions to operate
My Brada dishwasher is not draining and is beeping halfway into the cycle and not finishing. There is water in the bottom.
Sep 13, 2009 | Dishwashers
Brada dishwasher EF2401 - water in bottom
I just moved in to a new house with brada dishwasher, everytime I used the water leeks from the bottom, can somebody help me to fix it, or do you think I should throw it away and get a new one.
Sep 05, 2008 | Dishwashers
Dishwashers Logo
106 people viewed this question
Top Dishwashers Experts
