How to install a miller moc 100 mobile home furnace
3 Suggested Answers
  • 767 Answers
SOURCE: I have a miller furnace in my shop, runs on K1,
Check the filter on the tank to make sure it is not clogged. Then iff it still will not bleed take the screw out od the top of the pump usually a 1/2 inch or 9/16 and fill the pump with kerosene and then put the screw pack inand try to bleed. sometimes priming the pump will get the pump running again because it air locks the when it is run out of fuel.
Posted on Jan 15, 2010
  • 67 Answers
SOURCE: I have a Miller furnace with central air. I am
Yes it can do but you will be better off by gone to a gas heater. MY own furnace was chance over to propane and didn't workout to good. Less then ayear i have put in a new heater. Ken's Repair
Posted on Jan 19, 2011
No a miller furnace I was told a nozzle was for homes and b was for mobile homes furnace. I have a miller furnace I want to put what is the right one in can you help me
Did you have an old nozzle to look at? The one that you're replacing? The Miller gun furnace for mobile homes is probably a .75 gal/hr. nozzle or less. You need a furnace tech to look at your furnace if you can't read the info. stamped on the nozzle. It will have a .75, or .65 maybe gal/hr rating and a number for the angle in degrees.Like 80 degree nozzle.
If you match up what came out of it,you should be fine. don-ohio (:^)
Dec 27, 2016 | Heating & Cooling
How do I get the panels back on my Coleman motor home furnace? I changed the filters and now I can't get the panels back on
please one post,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman 7956-336p Mobile Home Furnace Gas...
Furnace will not stay lite, flashes pressure valve closed
Too much or too little pressure. Check for air blockage or an ice blockage inside or outside the house. Were flames good color when lit?
Nov 12, 2014 | AO Smith Miller / LSI / Home / Nordyne...
FURNACE WONT FIRE UP ,LIGHT INDICATOR SAYS PRESSURE SWITCH OPEN W/ INDUCER FAN ON
PROBABLY MOISTURE IN PRESSURE SWITCH OR SNOW OR ICE BUILD UP NEAR VENT TERMINATION . PROBABLY JUST A BAD PRESSURE SWITCH
Dec 17, 2013 | AO Smith Miller / LSI / Home / Nordyne...
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Intertherm oil furnace in mobile home installed 3.5 years ago. Worked great until the Igniter transformer shorted out 1.5 years ago. When technican changed the transformer he also changed the burner...
hello,The 90* nozzle is usally installed in miller brand units because of the "short" chamber.The 90* should not cause soot.Soot = not enough primary AIR into the burner mix.If the unit mfg. wants .50/80*a it should be used.#559 might translate into a .65gph input thus overfiring the unit.If a .50gph is installed the AIR mix problem will take care of itself (less fuel).Soot is unacceptable in your (young)3.5yrs unit and should NEVER have soot at all.The problem started when the nozzle was replaced try (insist) on mfg spec. nozzle.
Nov 08, 2010 | Intertherm Heating & Cooling
Miller propane furnace .red light flashes 5 times
Look on the wiring diagram for an error code chart. It will give you a starting piont.
Dec 01, 2009 | Polaroid Heating & Cooling
Installing a boiler
Set the Miller to turn on at 7-10 degrees lower than your wood boiler. Make sure the Miler works by turning up the t-stat 10 degrees higher than room temperature first.
Sep 13, 2008 | Empire DV-215 Direct Vent Natural Gas...
Mobile home miller propane gas heater
Sound like the blower motor is burning out. after it has run for a while, shut off the power to your furnace, then fell the motor. if the motor is really hot(be careful) then its starting to burn out. This is a very common symptom of this.
Nov 25, 2007 | Heating & Cooling
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
